Need manual for playgo paper recycling - Office Equipment & Supplies
What is the best answer to 'paper or plastic?'?
According to me, Paper is better than plastics because papers are more ecofriendly than plastics but in some cases, plastics are more useful than paper.
Paper is better because they are biodegradable and can be decomposed and recycle easily Whereas plastics has its own important uses but the main disadvantage of plastic is that they are non biodegradable and cannot be decomposed by the microorganisms.
But this problem can be removed if we will recycle and reuse these plastic materials properly and don't throw in soil and water bodies. Throwing them can cause extreme harm to plants, animals and also our environment.
Jan 04, 2017 | Green Living
Can you put magazines in the paper recycling bin?
Yes, you can put newspapers, magazines, junk mail and any other kind of paper related products in a paper recycling container.
Jan 17, 2013 | Home
Sticking paper
Do not use recycled paper in this machine if you can. I would also try to fan the **** of paper before installing it in the machine.
Aug 02, 2010 | Lexmark Office Equipment & Supplies
I have a Panasonic DP-8020E with a consant wrench light on. I have recycled the power and it did nothing. It also is asking for paper have you ever heard of that?
The wrench being displayed is most likely a P.M. counter or a cleaning web counter. It will soon lock the copier up, till the counter is reset after replacing the parts that are needed. The copier maybe looking for paper in the manual feed tray. Try puting paper in the manual tray and see if the problem goes away. Good Luck
Jul 29, 2010 | Panasonic DP-8020E Black and White Copier
How to reset pin number for toy safe 'My home fun' made by playgo ltd
If the safe is open start at 1, if not remove the front key pad panel by undoing the 2 screws and remove so the open sound sounds. 1:Press and hold the * star button until a tone sounds.
2: Enter the new pin number
3: Press # FINISH should show on the read out.
replace the keypad panel and your done.
Hope this helps
Aug 08, 2009 | Playgo Ltd Toys
Paper jams in printer.
Most ink jet printers should be able to handle either 20# or 24# paper. Some will have trouble with recycled products. Check your printer manual - there may be an adjustment for paper weight.
Mar 28, 2009 | Canon MP610 Photo All-In-One Printer
k24674
jasbo
jasbo
