Repair infrared space heater
No heat every thing else has power but tubes do not heat up
    Master:
  • 474 Answers
It might have a fuse that has been blown internally. This may have happened to protect it from over heating because it was left on too long or something went bad and it got too hot.
Posted on Dec 08, 2014
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Tip
DeLonghi Space Heater does not Heat
<p><b>Space heaters</b> are becoming more common as people are trying to get their<b> energy costs</b> under control. To try and s<b>ave money on heating</b>, many people are <b>turning down the heat</b> for their <b>central heating systems</b> and then heating just the area that they are in with a <b>small electric space heater</b>.<br /> <p><br /> <br /> <p>While these<b> electric space heaters</b> are relatively inexpensive, there are many people who want to repair their space heater if it stops heating. <br /> <p><br /> <br /> <p>If you have an <b>oil filled type space heater</b> and it is leaking or you are thinking of refilling it then check out this tip.<br /> <p><br /> <br /> <p><a href="/../support/r7770415-oil_filled_radiator_heater_leaking">Oil Filled Radiator Heater Leaking</a><br /> <p><br /> <br /> <p>If you have an <b>electric hot air space heater</b>, and it is not working, then there are only a few things that can go wrong. The only parts that can fail are the <b>switch(s) for the heating</b>, the <b>thermostat</b>, and the <b>heating element</b>. Of these parts, the <b>switches</b>, and the<b> thermostats</b> are replaceable, but the <b>heating elements </b>usually are not. Finding the<b> replacement parts</b> can also be difficult. Here is one website that carries many of the parts for these heaters.<br /> <p><br /> <br /> <p><a href="http://www.ereplacementparts.com/">Click Here</a> <br /> <p><br /> <br /> <p>To find out which part exactly is the part causing your problem, you will need to follow the power through the switch(s) and the thermostat to the heating element(s) and find out where and if the power is being interrupted before getting to the heating element. If the element is getting power then everything else is working and the element is bad. If there is no power there then go backwards till you find power and replace that part.<br /> <p><br /> <br /> <p>Always remember to mark any wires that you remove very well before removing them. There are many people looking for<b> wiring diagrams</b> because they have not remembered where they removed the wires from.<br /> <p><br /> <br /> <p>Also make sure to remove power, (unplug the cord) before removing any electrical components from the heater. Also when checking for power with the power on, you must be very careful to avoid a shocking experience that could result in death. Make sure all parts are away from metal parts of the heaters also to avoid shorting the part to the heater and blowing a breaker or ruining the heater.<br /> <p><br /> <br /> <p>In many cases, the time, energy and the <b>cost of parts</b> and shipping are not worth the <b>cost of the heater</b> that you are trying to fix. Make sure to check all of that out before trying to make repairs.<br />
on Jan 15, 2011 | Heating & Cooling
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
