Question about Radio Communications
My radio is not transmitting what could be wrong
  • 4 Answers
When the batteries are reaching the end of their life or in need of charging the first thing that is likely to happen is that the unit will be weak when transmitting while receiving just fine. This is because it takes a lot more power from the batteries to transmit than to receive. Try a new set of batteries or if rechargeable then try charging the unit. With regard to regular batteries, make sure your batteries say "alkaline" on them somewhere since they will last much longer and also are more likely not to leak inside which can ruin your radio. Ignore labels on batteries that read "super heavy duty" or other such nonsense. Look for one and only one word "alkaline" on them and buy any brand you want to since cheap or expensive they are basically the same. Don't waste your money or risk your radio by using anything but alkaline batteries.
Hope this helps.
Posted on Dec 08, 2014
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
Kenwood tm-281a transmitting but no one can hear me.
How is your antenna? Do you have another 2 M radio? Try feeding a dummy load and listening on another radio nearby. Look at the display when you transmit. Does it show the right frequency? If you have the offset wrong and it is taking you outside the band, it will likely not transmit. Do you have a power meter? Does the rig's current drain go up when you try to transmit? (Does the power supply keep the voltage up when you try to transmit?) Supply voltage dropping will cause the rig to NOT actually transmit.
Nov 14, 2014 | Radio Communications
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
Atlantis 250 will receive but won't talk out, could this be a faulty push to talk button?
Are you sure it isn't transmitting? do you have a PL encoded on the radio you are using as a receiver? disable it so you can hear everything on it. the wrong digital squelch settings between the two radios will make it look like one of them is not transmitting.
Oct 23, 2013 | Radio Communications
I have a tk -250 and I can hear everyone talking but when I try to respond to them all it does is beep
Are you sure the people you hear talking are in the band limits of the radio. Generally, when they beep on transmit it's because you're trying to transmit out of band. If the stations you're hearing are near the band edge it's possible you have the "offset" wrong and when you hit the PTT, the shift (offset) in the wrong direction is taking the radio out of band.
Sep 16, 2013 | Kenwood Radio Communications
I can't get my ntl twr500 2 way radios to conect to each other
Do you hear anything on one unit when transmitting on the other?
If you do, it will show that the unit is transmitting.
One or both might be set on the wrong channel.
Check both units this way/ Check each to see if they are receiving any signal when the other transmits. Hope it helps.
Tom
Mar 26, 2013 | Cobra microTALK LI 7200-2 WX VP Two Way...
Radio will "receive" but not "transmit". Radio, antennas, and wiring are all less than two years old. Should I try a new mike?
Firts you have to check for carrier.For this you need an swr meter.2) Check continuity between the pl259 tip and antenna.3) Check for modulation (voice) if all of the above are OK. 4) Check if your display changes to transmit when you press the mike. IF all fails,then try another mike.
Jan 27, 2010 | Cobra 29 LTD CB Radio
Radio stuck in transmit meter needle is slammed all the way to the right as soon as you turn unit on
Have you recently changed mics ? if so it is wired wrong, if not I would check for a shorted wire in the mic connector or the mic itself.
May 25, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Have Cobra 29 LTD CB Radio w/ bluetooth. Power comes on. Does not receive or transmit. What's wrong?
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Dec 20, 2008 | Cobra 29 LTD CB Radio
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
