I have sharp es-a70s washin machine how to work with out dor lock switch
    Champion:
  • 242 Answers
If this is a front loader, it is very bad idea to attempt to bypass door lock, just get it serviced and new part installed. if it is top loader, and you mean the lid lock, then you can bypass this under the top panel at the rear of the machine. though this is dangerous too, it won't cause a leak. why are you doing this?
Posted on Dec 08, 2014
Replace dor latch spring in Sharp Microwave R-1850A
Usually this can be done easily by removing the door unit and removing the panel to the door wherein you will be able to get access to the door lock. If there is no damage to the pivot or the post to hold the lock and spring , you can push the spring and reset.
Sep 03, 2014 | Sharp R-1850A Convection/Microwave Oven
Sharp washing machine won't unlock door
I was going to suggest switching t off for a while, allowing the thermal lock to release.
Mar 22, 2014 | Washing Machines
Unlocking sharp
These machines are set that way. Once started, even if you stop it you have to wait for a timer to unlock it which takes about 3 minutes.
Jun 30, 2013 | Washing Machines
My washer wont lock and now it does not spin why
The door has to lock as a safety to allow the machine to run. There is a switch on most locks to tell the machine to power the motor.
I would guess the lock solenoid has failed, or something has happened to the latch for the door.
Sep 16, 2012 | GE WBVH6240F Front Load Washer
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
Something iside the door gave out outside handel doesnt work just
Follow the screws on the inside of the door. There will be several to find and then you can remove the inside door panel cover.
Jun 29, 2009 | 1998 Lexus ES 300
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
