Question about Electrolux Vacuums
Is a electrolux carpet beautifer model A69913Z used to clean carpets
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Yes, what you're referring to as the model number is actually the serial number of this unit.
It is indeed designed for shampooing and polishing any floor with the correct brushes, etc.
It works EXCELLENT if used properly.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Posted on Mar 15, 2015
jyackle5
  • 8197 Answers
SOURCE: i need to know how to clean the carpet using the vax carpet
Here is the manual.
http://www.manualnguide.com/dl/20341/
Good Luck and please Rate Fixya!
Posted on Mar 16, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: The manual for my hover steamvac was lost I would
You can download the manual here.
Posted on Mar 30, 2009
ukvacfan
  • 328 Answers
SOURCE: I require instructions on how to use the Bissell Powerwash
Contact the Bissell services in your country - most of the Bissell sites (www.bissell.com) for example have Adobe user instructions of which you can download.
Posted on Apr 02, 2009
SOURCE: 9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Posted on Aug 29, 2009
SOURCE: Carpet not getting moist
Huh I had this issue. It was killing me only used it like six times then no water. I took this apart four times man. They told me it was the pump. I finally ripped it all the way down. It was the pump. But it was the black connector on the main motor. Which runs the pump it came loose. I pressed it back on problem solved. Make sure you crimp it a bit. so it does not vibrate off again. Hope this helps.
Posted on Mar 28, 2011
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
Need instructions for a Electrolux Epic floor pro Heavy duty carpet shampooer
go to www. electrolux.com and download your model.
God bless you
Jun 20, 2012 | Electrolux Floor Pro Vacuum
I sucked up a sock into the carpet attachment of my electrolux 3500 series and the carpet attachment cut off. After the sock was easily removed (it was only wrapped around the brush part) I reattached the...
Did you press the reset button? There will be a reset button either on the back of the unit just below the bulkhead or on the top side of the base.
Locate the reset button and press; this should allow the carpet attachment to resume operation.
If you require an Owner's Manual try downloading the Epic 3500 manual from this site:
http://www.aerusvacuums.com/support/manuals/index.cfm
May 01, 2011 | Electrolux Epic 3500 Vacuum
Can I lift the vacuum beater bar higher up? Bought new carpet and would like it to push smoother!!! Bought a shag carpet
No. The Electrolux (Aerus) uprights are auto adjusting to the height of the carpet. Make sure the brush is spinning when the vacuum is on. If it's not, this will cause difficulty in use.
Apr 06, 2011 | Electrolux Epic 3500 Vacuum
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
ELECTROLUX / ULTRALUX VACUUM
I assume that you are talking about the power head for cleaning carpets. If so I have a spare.
Dec 29, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
