Question about Sony BRAVIA Televison & Video
Why does my tv stop.when I use number 3 my Sony Bravia looses picture &sound
I have turned the tv off at the set & waited for 20min. No work yet.
    Top Expert:
  • Sony Master
  • 75,462 Answers
Contact the authorized service center for Sony. It sounds like corrupted firmware. Electro help
Posted on Dec 08, 2014
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 73 Answers
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Posted on Oct 15, 2009
  • 8457 Answers
SOURCE: sony bravia screen doesn't work but sound still
Ur Video converter board is dead,need a new one.
Posted on Oct 18, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
Sony Bravia KDL32XBR9 repair
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 18, 2016 | Sony Televison & Video
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia kdl- 4052510 picture but no sound from my dvd player
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
Nov 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY DAVHDZ278 BRAVIA HOME THEATRE SYSTEM SURROUND SOUND PROBLEMS
OK, it is called Cold Reset
Turn unit ON and press following 3 button on same time..
STOP - EJECT - POWER
Display will show Cold Reset briefly and DAV-HDZ278 is reset to default settings.
Thanks.
Aug 20, 2009 | Sony Audio Players & Recorders
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
