Question about Sewing Machines
I have a Babylock BMP8 that i have an x-axis home position error. How can I fix it without spending hundreds to take it to a technician that is hours away! Please help!
I have tried turning machine off & back on turning machine on while holding outer 2 buttons and recalibrating hoops.
    New Friend:
  • 185 Answers
Turn off and unplug machine. Manually move hoop frame front to back and left to right.
Plug in and turn on. Motors driving hoop x and y axis should initialize. If not you must see a tech, If the frame will not move see the tech
Posted on Dec 15, 2014
dupina
  • 110 Answers
SOURCE: Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Posted on Dec 12, 2007
SOURCE: Inapproipiate needle stop position THEN Main Motor Lock comes on
The BELT was OFF. I guess it did that during shipment to me. So my husband just put it back on. THAT SIMPLE. It just kept making a motor trying to run sound and my husband took the left top cover off and seen it was only the belt. I was SO excited. It saved me a service call.
Posted on Feb 08, 2009
  • 192 Answers
SOURCE: embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: hoop errors
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
Posted on Jun 10, 2009
lalmarsalko
SOURCE: Problem with my Babylock embroidery machine
I had this problem. You need to be sure that the upper thread is not catching on something. Also, be sure to take out the bobbin case and brush out the area in and around that area throughougly, after every use. Lastly, use a good brand of thread.
Posted on Jan 24, 2010
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
I had this error message on the screen panel: x-axis position error. How to fix this problem?
have you tried googling (searching) on that sewing machine model and manufacturer and doing a query there. I bet they have advice on this situation.
Jan 24, 2015 | Sewing Machines
Why is my thread nesting on my Babylock BMP8?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Jan 14, 2013 | Sewing Machines
Bernina Aurora QE presser foot recurring error
take it to another repair shop to get a second opinion
May 28, 2012 | Sewing Machines
How do you unlock the safety device on a babylock espire sewing machine without going back to a dealer?
hi Katester.
not sure if you have the manual but if you go to this link it has the manual and you can read up on it.
http://babylock.com/ftp/whitepapers/Espire_BLSR_InstructionManual.pdf
or go to this link but i could not find much on there but have look.
How do you unlock the safety device on babylock espire sewing machine...
Jul 24, 2011 | Baby Lock Espire
Sewing Machines Logo
300 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
