Question about Vizio Televison & Video
TV will not turn on manually or with the remote
Unplugging the tv changing batteries in the remote
    Top Expert:
  • Vizio Master
  • 34,188 Answers
Possibly an open fuse or power supply failure
Posted on Dec 08, 2014
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
  • 8457 Answers
SOURCE: the remote control does not power the TV on and
Tv remote probally have dead CPU chip,all remotes devices heavily depended on it CPU chips.Try website like Remotes.com to buy an exact remote or very close to the original remote.
Posted on Feb 05, 2011
Testimonial: "thank you for your quick response- the information really helped me solve the problem"
paul4265
  • 592 Answers
SOURCE: TV will not turn on. Red flashing light, nothing
Hi.
This sounds like you are experiencing the same thing as thousands of other tv owners right now.
Your tv is suffering from " capacitor flu".
The capacitors that control voltage regulation, convergence, or the ones on the main board have failed.
This is not due to anything that you have done, it is because about 15 years ago, some companies chose to put profit ahead of quality.
There were about 20 electronic component manufacturers in the mid-1990's that mass manufactured capacitors, and they were done so with the wrong formula for capacitance gel. They used a formula which was later determined to be harmful to the capacitors, but instead of pulling those off of the market, they ignored the massive failures and left then out there on the market anyways.
All together, the companies made a combined 50,000,000 capacitors that were junk, and instead of lasting the 25-30 year design like they were supposed to, some of them are only lasting a few months to a few years, at best.
Now, that isn't to say that this means that your tv should be tossed in the trash, but if you take it to get it repaired at places like BestBuy, Fry's, or Staple's...you will want to get an estimate of repair costs before actually having it done.
The reason for this is because to get the proper capacitors put in your tv is a time consuming, and expensive repair.
You may find that the cost of repair is more expensive than the cost of replacing the tv, or you may find that it reasonably priced to get the repair.
That is why I recommend getting an estimate first.
This way, you will know ahead of time which way is the most economically feasible venture for you.
I hope this helps you understand what is going on with your tv, and that it gives you some insight as to how to remedy the situation.
Good luck to you, and have a good day.
Posted on May 31, 2011
walesarumi
  • 6993 Answers
SOURCE: The TV will not respond to the remote and
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Posted on Nov 28, 2011
My remote does not work for my Apex TV
it may be a time to buy a new tv. it would cost more to fix that one than to buy another tv
Nov 22, 2008 | Samsung TV Remote Control
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
FPA Lock can't turn Tv on
I posted the above - I went to WalMart, bought an $8 remote and a .98 pack of AA batteries. It turned the TV on immediately. Problem solved for less than $10.
Sep 16, 2007 | RCA 14F512T 14" TV
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
