Question about Sewing Machines
Keeps breaking needles - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Posted on Dec 08, 2014
    Problem Solver:
  • 19 Answers
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
My 2003 Brother sewing machine is needle keep on breaking when I try to sew
http://www.sewingandcraftcorner.com/why-does-my-sewing-machine-needle-keep-breaking
If it continues to break needles, most likely the machine has been knocked out of time. Search for sewing machine timing or take it for repair.
Mar 22, 2017 | Brother Sewing Machines
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
Why does the right needle keep breaking in myloc 634d
I agree with John Smeed It could be that the needle is bent or in the wrong way if it keeps on breaking it must be hitting the throat plate or it's timing may be out( a pro job) Also check the needle is in as high as it can go.
Apr 19, 2014 | Janome MyLock 634D Mechanical Sewing...
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
My machine keeps breaking the thread
Mar 02, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
The needle keeps breaking.
make sure the needle is set to the correct position
Jan 27, 2009 | Husqvarna Freesia 415
Sewing Machines Logo
73 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
