Question about Nintendo Video Game Consoles & Games
How do I get an account for dgamer on the dsi xl?
I've tried to get an account using my Nintendo WFC ID code, but no luck. I've been getting error codes like this one: 206684. My Dsi xl model number is this:ww447257555. And whenever I try to connect to the internet, I keep failing and getting even MORE error codes. I just can't seem to connect to the internet. Also, can you PLEASE give me a credit card number so I can download new games to my ds? THANKS!!!!!!!
Error code 051099
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en
Dec 22, 2011 | Nintendo DSi XL Burgundy
Error code: 051099 - 1
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
this is the solution to your problem
Mar 05, 2011 | Nintendo DSi XL Burgundy
Error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
Jan 30, 2011 | Nintendo DSi Matte Blue Console
My wii keeps saying error code: 204969
Error Code: 204969 Nintendo DSi Shop Errors - Network ErrorThere was an issue with your connection to the Nintendo DSi Shop. Please try the following:
  1. Go into the Nintendo DSi menu (Wrench icon on the main menu screen.
  2. Select "Internet," and "Connection Settings."
  3. Erase your existing Internet Connection Settings and set up a new connection.
  4. Once you have established and tested a successful connection test, try the connection to the Nintendo DSi Shop again.
If you have verified that your Nintendo DSi or Nintendo DSi XL system's internet connection is working, then there could be a temporary issue with the Nintendo DSi Shop. Please wait awhile and your connection again.
If you have tried the above troubleshooting and are still receiving this error code, please call us 1-800-255-3700 so that we may assist you further.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=204969&system=DS&locale=en_US&action2.x=21&action2.y=33
Nov 23, 2010 | Nintendo Wii Console
Error code : 051099
Error Code: 051099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
If after trying the steps above you are still receiving this error code, please call 1-800-255-3700 for further assistance.
Jun 19, 2010 | Nintendo DSi Black Console
CANT GET ON INTERNET
May 28, 2010 | Nintendo DSi Blue Console
My nintando DS gets error code #51099 everytime I try to connect to the internet on pokemon soul silver. Do you have any ideas?
Error Code: 51099 This error code can occur for two different reasons:
Apr 20, 2010 | Nintendo DS Lite Console
Can't get connected to the internet says error code 51099
Mar 28, 2010 | Nintendo DSi Blue Console
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
