Question about Bosch Vision 300 Series WFVC3300UC
I have a Bosch 300 vision washer which wont turn on. The lights are on and there is no error code showing does anyone know what might be wrong?
Unplugging the power cord checking to make sure the soap drawer is closed and the door is closed.
I have the same issue. Were you able to fix it and what was the issue?
Posted on May 11, 2015
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 240 Answers
Lights are on, but won't turn on? I don't understand. if it simply won't start turning after filling, this could be the motor brushes. if it isn't starting at all, you may have an issue with the door mechanism.
Posted on Dec 08, 2014
Water is coming out of the drawer when in a cycle and leaking on the floor
g'day, water fills up drum via soap draw. this is how the soap mixes with water and enters the drum. U might need to check hose clumps and hoses that enter onto the back of draw (you'll need to access the top of machine when machine is unplugged). Also be sure to clean draw as soap can build up causing problems. Be sure draw is closing properly. Hope this helps. Let us know how u get on.
Aug 08, 2011 | Washing Machines
Soap dispenser will not open.
the detergent dispenser is located behind the door panel. it is actuated by an electrical signal that powers a solenoid. two problems are possible. 1 the solenoid is not getting power or is defective, or 2, the linkage that connects the solenoid to the door release is broken or has come loose.
there are a few screws down each edge of the door ( usually phillips head) . sit in front of the dishwasher with a towel on your lap. remove the screws on each side and let the door panel fall in your lap on the towel. once the panel is off, you will see the back side of the detergent compartment. if the seal around the detergent drawer is leaking, you may find the solenoid electrical connection is corroded. ( unplug the dishwasher or turn off the breaker, as the solenoid is actuated by 110vac). if this is the case you may be able to clean the connnection. close the detergent drawer, and push on the plunger of the solenoid. the drawer door should pop open. if not, look for any binding in the linkage. if all looks well, run the dishwasher with the door panel off. when it gets to the main wash cycle, check the two terminals on the solenoid with a volt meter. if you never get power, it will be a bad control board. if you get power but the solenoid never actuates, you need a detergent drawer assembly. they are fairly inexpensive, and usually the seal fails causing the solenoid to get corroded.
Nov 20, 2010 | Whirlpool DU943PWK - Multiple Color...
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
False door open reading on my aficio 350
Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without saying as.
Aug 10, 2009 | Ricoh Aficio 450 Copier
Drawer won't open on my sanyo vhs dvd
check the front of your dvd has it got a small hole located on the facia just below the draw if so unplug your unit and insert an unfolded paper clip in to this hole as straight as you can you will meet some springy resistance that is the door locking mechanism push gently and the door will open .. once it has leave the door open and power up the unit the door should close and reset ... oh and make sure your kids ( if you have any ) havent dropped any M&Ms or stuff into the draw common problem Kids love em ?.
Regards Vortash
May 12, 2009 | Sanyo Televison & Video
Leaking washing machine
TO FIX THIS PROBLEM I WOULD FIRST TAKE OUT THE SOAP DRAWER AND CHECK THE HOSE AND MAKE SURE IT IS NOT CLOGGED WITH WASHING POWDER AS IT CAN BECOME HARD AND BLOCK THE PIPE BY 50% ALSO CLEAN UNDERNEAT AND AROUND WHERE THE SOAP DRAWER SLIDES IN REGARDS UNDER THE DOOR MAKE SURE THAT THE RUBBER IS SPOTLESS AND SITTING PROPERLY .CLEAN UNDER THE DOOR AS WELL.
Jul 14, 2008 | Hotpoint Aquarius WD63 Front Load...
GE Front Load Washing Machine
It sound like a lid switch problem. Since your washer is still under warranty you should contact GE service center for their assistance. Good luck!
Aug 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Lights On...Goes Out
there may be a "door closed" position switch that has been "bumped" during the process of soap dispenser drawer removal. the switch prevents accidental water leaks if door is open. your machine has a switch that is telling the control board that the door is open
May 21, 2007 | Kenmore 44832 Front Load Washer
Bosch Vision 300 Series WFVC3300UC Logo
401 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
