Question about Food Processors
How do I get a mannual for my 'Williams Living Well Healthlivingwell processor
Pushed buttons reset button and cool off retry again. Lost mannual. Please send me another. A product this expensive should have support available. We. Have enjoyed this product but evidently we are missing a step or two. Please, please send us a step by step mannual.
I have a food processor that worked fine the last time it was used, now it will not do anything.
You have probably solved this by now but generally it will be replacement of either the bowl or the lid to solve it. The mechanism is not overly robust within the handle & lid, movement gets lost and it won't activate that switch just above the button panel.
Nov 24, 2015 | KitchenAid Food Processors
My processor has power but will not operate,it needs resetting can you help please?
If it doesn't have a resettable external fuse button then it will need more than a reset. Check and make sure that the bowl & lid (and pusher sometimes) are activating the safety mechanisms that prevent the motor starting if not assembled correctly. If that's all fine then you will need to open it up by removing either the base or the top cover and get your multi meter out and follow the circuit.
Aug 03, 2015 | Cuisinart DLC-3014 Food Processor
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
Motor does not start when button is press down. Lost receipt cannot return to Chef's catalog.
the problem with in your button you must be check that after that energy will be reach there and it will do work properly
Jul 07, 2011 | Cuisinart DLC-10C 7 Cups Food Processor
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
It won't start
The power lights go on put the machine does not run.
Nov 22, 2007 | Cuisinart DLC-5 Food Processor
Food Processors Logo
55 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
