After couple of loads you must unplug and plug back in and work with it until it Wii wash.
SOURCE: nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
SOURCE: Takes 3 hours to wash a load of clothes
make sure you are using soap the is for front loading machines. (he)
SOURCE: sounds like rocks in my front loading washing machine
did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
SOURCE: 3 hours wash cycle
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports. Make sure they are clear of rust or debris. Based on your description, pay particular attention to the hot water side. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
