Question about Lands Phones
How do l return a charger for cordless phone the does not charge on this unit but charges on the other units
I've tried everything in the Manuel that's when I switched the phone to another unit
  • Lands Phones Master
  • 3,368 Answers
First try replacing the battery
Posted on Dec 09, 2014
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
Garmin nuvi 40 will not charge
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Oct 31, 2012 | Garmin Nuvi 40
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
The base unit will not charge hand sets . I have cleaned the contacts on base unit as recommended. Please note the remote unit charges both handsets.
The problem is in the remote charger or batteries in each phone is the issue. If you are handy with a meter, "set it to DC volts" press down on the charging tabs, you should have at least 3.6V to 12V if it reads 0 the remote charger is defective.
May 26, 2011 | Panasonic KX-TGA560 Cordless Expansion...
Phone does not charge and all phones in house do not work
Your base unit doesn't work, maybe it has no power. So it can't work and charge the phone. You must change the charger with another identic one( maybe one from the other unit you have)
Mar 29, 2011 | Uniden Cordless Phone
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
Handset will not charge
firstly, try to use another charger, if the problem continue, you can replace the battery of the phone and if this still continue replace the charging port with a good one .
Jun 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
W800i not charging
Since you've got a new charging unit, you may need to try using different battery. If same problem occurs, then plug the charger to the phone and slowly wiggle the charger to see if the power jack is loose.
If everything looks okay, then there's a loose connection inside or a bad IC that needs to be replaced. And you may need to contact the manufacturer for repair.
Have a great day!
Oct 18, 2009 | Sony Ericsson K800i Cellular Phone
Unable to register the handsets to my Corded/Cordless combo phone
You must charge each phone individually on the main base unit for at least 20seconds before use. Do this with each phone-again on the main base unit, then you should be able to register and return other phones to separate cradle. I hope this works for you
May 26, 2009 | Uniden Cordless Phone
I have a Panasonic cordless phone, 2 handset model #KX-TGA101CS. Phone # 2 doesn't want to charge. It's been on the charger overnight and I can't get it past 2 bars. They are only about 2 years old. They...
Start by swapping the batteries between units. If the formerly bad handset charges, it's a battery. If not, look for dirty contacts where the unit sets into the base or the batteries fit into the holder.
Carl
Sep 01, 2008 | Panasonic Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
