Question about Samsung Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
I tried using different wash cycle like: fuzzy, blanket to see if after the wash cycle and its time to rinse, the water would turn off after it is full and the rinsing has started. But the water keep running. I have to stop the machine and change cycle to spin so as to drain the tub. Please HELP!!!!!!
I think the door has been banged
its not a tight fit bad seal etc..
so as to form an air lock
something like this i note from other forums
Posted on Dec 10, 2014
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
295 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
