Question about Ovens
My Omega OF90XA oven is not working. the right oven element stopped working so I replaced that now both oven elements do not work. Fans and everything else work. Please help.
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
SOURCE: Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Posted on May 15, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
Snz9imfx1 looking for the manual electric oven gas hob problem not getting super hot as it used too, have replaced the elements, thermostat appears to be working.i wonder if there issues with fan
Make sure the elements are the same. The fans should be in working order otherwise the elements get too hot before the oven and shuts down
Aug 30, 2017 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
My Omega oven has stopped working: single oven, air forced. The power is on, fuses intact, the timer works, the selector knob works, but when the thermostat is set the "oven on" indicator does...
The oven has a thermal trip switch behind the back wall of the oven and is under the back cover. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. If you are handy you may be able to open the switch and click the little disc backwards and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Mar 27, 2011 | Ovens
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
To blow the house trips it must be the element
Thermostats do not normally go short circuit.
The elements can be replaced quite easliy and cheaply
I would check that the fan is turning freely before you buy the element
Feb 24, 2010 | Ovens
I need a manual for omega oven,model not known.
Hello. If your stove is manufactured by Omega Appliances, it appears that they no longer produce it. That said I can speak to your heating element issue. When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you would like to contact the Omega Appliance company directly, you can reach them as follows: http://omegaappliances.com/contactus.php
Nov 20, 2009 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
The oven just stopped working in our hotpoint ew51 cooker everything else still works any idea,s
the oven control switch is bad, or you have a burned out oven element top or bottom. If your broiler heat comes on, the top is o.k., then the bottom element needs replaced
Aug 06, 2009 | Ovens
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
