Question about Hobart Lx30h Commercial Dishwasher
When the dishwasher powers up the display gets stuck displaying "23".
Turn the power off and back on at the main breaker. Hit the start button and the dishwasher starts powering up at the "HI" text in the display it changes to 23 and a constant whine can be heard from the machine. Everything is then frozen at this point. IE it won't finish powering up and won't respond to the on/off buttons. The only thing I can do at this point is use the breaker to shut the unit down. Any ideas on what to check for would be appreciated. Bob
kermit854
  • 38 Answers
SOURCE: hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Posted on Aug 20, 2008
pepsicrazy
SOURCE: Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Posted on Jan 13, 2009
SOURCE: Hobart lx40 Dishwasher stopped working
the reason according me this to be happend,is a short circuit somewhere in the machine,it could be the heater,solenoid valve or to be caused by any leakage,you may check the fuse and replaced if necesary,and if that continue you need a technician.
Posted on Apr 19, 2009
  • 109 Answers
SOURCE: E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Posted on Aug 08, 2009
  • 109 Answers
SOURCE: hobart am 14 constant power on rps 1+2, rinse
DPS1 and 2 are fed from L1 and L2 directly.
RPS1 and 2 get their signal from a relay, triggered during fill or rinse. Check inside the control box for the machine schematic and component location. Check that the relay only powers during fill and rinse. Check for welded relay contacts.
Note. Soap and rinse dispenses are often spliced into AM14's in unusual ways, and with unprotected pump circuits. (no fuses) These can be too much current draw for the contact rating of the relay.
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Washer doesn't start / lights up. Breaker is OK, electrical outlet too... What could be the problem ?? Control Board.. Fuse
More than likely it is the computer board. However it can be also caused by the main power switch or the door interlock switch. There is no fuse, the main power supply is part of the computer board. The switches are very easy to check but the front display panel of the dish washer needs to be disassembled as access to the main computer board is required. A multimeter it is also required for the switch verification. Make sure the main power cord of the dishwasher has been unpluged. Removing the front display panel it is not difficult. Once the front display panel is removed you have access to the main power switch and the door interlock switch. Unplug the power cord from the dishwasher and remove the connectors from both switches. Verify continuity on both switches using the multimeter. If you have electronics back ground skills you can also verify if the main computer board has power; for this you need to have both switches connected and the door interlock switch latched. You should be able to measure 110 volts AC on the two wires comming out of the main power switch connecting to the comptuter board.
Jun 08, 2014 | Miele 23 in. Novotronic G841 Built-In...
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
Is there a reset button on the dishwasher for the Fisher Paykel DD 605. I washed a top and bottom load, nothing unusual about the loads. The dishwasher just stoped and there is no power on either of the...
If there is no power on both the drawers then 2 things
1. the circuit breaker on the mains power supply feeding the dishwasher has tripped
2. the power board that feeds the drawers is faulty. This is located at the base under the bottom drawer.
The drawers won't open because the power has failed mid cycle and the drawer seal actuator motors are locked in down position.
You can force open the drawers but this could require some mechanical adjustments to the actuator yokes if the two sides are out of alignment when power is restored. In any case you will have to force open the bottom drawer to get access to the power board. The part looks like this but may not be the one specific to your model. You will have to contact a parts dealer local to your area.
The only reset function available is to turn the mains power off and back on.
Hope this helps. Please rate the solution if useful otherwise post a comment.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I cannot open the draw something is stuck in it
Your dishwasher has a top lid to seal the tube when it in operation. The seal mode is achieved by 2 actuator valves on both side of the housing pulling your top lid down. Model from 603 to current actuators are electric motor. For previous models they are vacuum pump activation.
When the actuators are bad they are either not pulling down the top lid causing a leak, or not releasing top lid back to its original position causing the lid stuck and the tub can not be pulled out as in your case.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see LD or LS, if you pass, keep doing it to get it back in a loop.
4- When at LD or LS, press lock to turn on, press a agin to turn off.
5- Listen to the sound of Actuators and at the same time, try to pull the tube out.
6- When it is done, just press the Power button to get out od the diagnstic mode.
7- If you are lucky, if just the seal to replace then it is easier than repalcing the actuators. Good luck.
Sep 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My oven is beeping!
F1 Circuit board defective Replace control board
Good Luck and Please Rate Fixya!
Jan 07, 2009 | Electrolux Frigidaire Professional Series...
Hobart Lx30h Commercial Dishwasher Logo
63 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
