Question about Cameras
Pocket juice max 7800 mah cuts on then cuts off after 5 seconds with a full charge
    Problem Solver:
  • 7 Answers
Sounds like your battery has lost its ability to charge. It could be damaged from either getting too hot, or dropping it. Age also takes a toll depending on the quality of your battery and the brand name also determines how long your battery will last if it is a rechargeable battery then it is limited to a particular amount of times being charged before it will no longer charge
Posted on Dec 08, 2014
How long does it take to charge a Tzumi Pocket Juice Rechargeable Power Bank
Should be charged within 5 hours, but the first and second time it can look as if it takes forever. Just remove it after max 5 hours and use it. The 3e or 4e time, it will acts as you want it to do.
Oct 29, 2014 | Cameras
Supertooth disco speaker issue
You need a new battery that supplies the full 2400 mah to unit. Batteries do wear out and the 1800 mah is not going to cut it.
Aug 24, 2017 | Audio Players & Recorders
Does the value of a battery capacity(mAh),larger than that specified for a laptop,mean any damage when used with it?
No it doesnt.. It just means that the battery can hold a larger charge.. I.E. the laptop will run longer then one with a lower mAh..
Mar 14, 2013 | Battery Biz Computers & Internet
New battery calibration, drain battery, windows will not boot
sounds like OS was not fully installed properly----Reinstall.
May 15, 2010 | ASUS Eee PC 1000H Laptop
I have dell inspiron 1100 with 6450 MAh battery which is death already, i am looking to buy new one, before doing it i would like to get some advise what is the difference between 4400 MAh, 5200 MAh, 6450...
MAH is short for Milli Amp Hr...
4400MAH battery - short time for the battery to discharge....it may work for 4 to 5 hrs....
7800MAH will work longer for say 8 to 10 hrs.....
also depends on what applications u use...if it contains many graphics and you keep watching movies then the working hrs gets further shorter....
hope this clarifies....offcourse...the 7800 will cost you more...than the 4400....
as far as what is suitable to you laptop check the mfg website or the manual that came with the notebook...some times...the power adpator also gives the battery specifications that must be used...
reg
let me know...
Mar 12, 2010 | Dell Inspiron 1100 Notebook
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Cameras Logo
327 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
