Question about Metra 99-4544 1982-1999 Chevy Cavalier Dash Kit Audio Radio Installation Stereo
How do I add coolant
Can not remove the stopper from res
  • Metra Master
  • 5,659 Answers
That is the only way to add coolant! Try spraying a freeing agent like WD40 on it!
Posted on Dec 08, 2014
My 2006 Caravan temperature gauge goes to red - engine is not overheating. Kick it into a lower gear (automatic trans) and the gauge comes back down. Is it likely the coolant sensor?
Could be.. is the system FULL? Air in it can cause some odd things. When engine and coolant are COLD (as in after sitting over night), open the radiator cap. Top off the overflow res with a 50/50 antifreeze / water mixture to HOT mark. Start engine, turn heat to hot and fan to high. Top off RADIATOR with same 50/50 mixture slowly & gradually. As the coolant circulates, it should bring any AIR trapped in the system (from heater core & engine block) to the radiator where you can replace it with the 50/50 mix. Once the coolant is HOT and stays level - about an inch under the opening, close the radiator. Monitor the overflow res and add as needed. Good luck!
Sep 23, 2015 | 2006 Dodge Grand Caravan
Why would i be going through so much coolant without a leak
Check your oil. There probably is coolant in it from a head leak. Also look at the exhaust . Should not be white and smoky. There is a leak somewhere.
Jun 07, 2015 | 2004 Chrysler PT Cruiser
How to fix oil in the reservoir
If you have oil in your coolant res. Its not a good sign. This means you have a blown head gasket. The part is quite cheap compared to the labour involved in taking the top of the motor apart. I would try flushing the coolant and with the new coolant add a bottle of head gasket repair. There are several different kinds, some are even industrial grade. It has saved me a couple times from huge mechanic bills. If this doesnt work then u may need to replace that gasket.
Mar 25, 2015 | 1998 Ford Expedition
93 GMC Safari overheating. This happened spontaneously. Runs hot very quickly when I drive it. There is antifreeze in both radiator and overflow res, overflow res fills up more after driving a bit. ...
It would appear your thermostat is stuck in the closed position , find where it is on your engine, drain coolant and remove thermostat housing and stat, replace housing(liquid gasket OK) and coolant. now run engine, turn heater controls to hot leaving filler cap off, top up any water to max and replace cap now warm up to temp until fan comes on. if all ok replace thermostat with a new one and new gasket, you could also flush the sytem out at the same time with a hose pipe by loosening one of coolent pipes and flush radiator.
Nov 04, 2013 | 1993 GMC Safari
Can a bad coolant resivior cause overheating
you may have a coolant that the res. can't keep up with is it going empty check the fluid in your radiator not the res. it may be low and not able to pull fluid from the res. look for leaks
Jul 06, 2012 | 1986 Ford Ranger 2WD
The engine coolant retrieval tank isn't getting
Replace the hose from the radiator to the reservoir.and make sure the reservoir is not leaking.
Feb 08, 2010 | 1994 GMC Sonoma
I just purchased a 03 wrangler. The coolant res
There should be a fill level mark and yes you need to put in immediately, run the car until it reaches operating temp, then see where the level is after you shut it off.
Jan 17, 2010 | 2003 Jeep Wrangler
Adding antifreeze to 2003 dodge dakota sxt
normaly you add to the plastic res , but lets make sure its full , so when it is cold the engine then open the radiator cap the metal one slowly and first top it off then close cap all the way and fill plastic res to the cold fill line. but usualy you just make sure the plastic tank is either full to the hot line or cold line , which is when the engine is hot or cold. but it is also good to check both .
Jun 09, 2009 | 2003 Dodge Dakota Club Cab
How do i fix the Coolant Level (ECL) Sensor
sensor is in the resivor if its a 2 pin connector jump it if light goes out replace coolant res
Nov 25, 2008 | 1998 Volkswagen Jetta
Normal Engine Temperature but Coolant finishes daily, No leakeages traced
headgasket can leak and comprssion is compressing air into coolant system as well as burn it.check for white spark plugs ends.start engine cold with cap of off res rev engine if coolant blows out of resivor at you headgasket is fried.
Jun 13, 2008 | 2008 Volkswagen Gli
Metra 99-4544 1982-1999 Chevy Cavalier Dash Kit Audio Radio Installation Stereo Logo
60 people viewed this question
Top Metra Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
crkuc
Are you a Metra Audio Player and Recorder Expert? Answer questions, earn points and help others
