Question about Sanyo Kyocera Zio M6000 - Black Smartphone Sprint
Clear all date reset the phone to factory reset
    New Friend:
  • 49 Answers
Choosing Clear all data or Reset device is the same and will return the phone to original factory settings deleting pics, vids, messages, and any downloaded apps.
Posted on Dec 07, 2014
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
Nokia secret codes
*#06# : Display the IMEI (Standard GSM command, works on all phones)*#0000# : Display the firmware version and date*#92702689# : Here you can view the S/N and the IMEI as well as the life timer (newer models). The date the phone left the factory and the date it was purchased. If your phone has been repaired the date of the repair is also visible. You will need to turn the phone off to exit this menu. Newer phones simply require you to press ok.
*#2820# : Display the Bluetooth MAC address (Phone must have a built in bluetooth adapter)*#7370925538# : Reset the mobile wallet (Phone must have the mobile wallet feature)*#7370# : Soft-format the memory (Symbian)*#7780# : Reset to factory defaults, confirmation required (also known has a Hard-format), all phone contents will be wiped clean including contacts and smses if they are stored on the phone
Mar 26, 2012 | HP Computers & Internet
Can Anyone tell me how i can reset the master security code for Nokia 5320XM????
Soft ResetSoft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard ResetIt may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
  • Enter the code: *#7370# and press Yes to confirm initialization.
    • Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information: contacts , memo...etc
Reset a Nokia 5800Press simultaneously the 4 button:
  • Green button
  • Red button
  • Camera button
  • On/off button
If you perform properly the above manipulation the phone restarts and you must enter the time, date ...
Mar 17, 2011 | Computers & Internet
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
Performing a factory reset via settings
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 | Cell Phones
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Unlock codes of nokia 2610
Once you get the unlocking code you get the unlocking instructions from http://www.mobileunlockguide.com/ .It's useful for you.
Aug 28, 2009 | Lands Phones
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
Nokia mobile phone model 6101.
Try reset your phone to its factory settings!
Go SETTINGS..... RESET FACTORY SETTINGS......then 12345 for the sec code.
if nothing happens, then bring your phone to service shop then let them solve the fault. im think there is a need to replash the firmware.Is this advice/solution helpful to you? You can send me email at st_nardz@yahoo.com for my further assistance. Kindly rate this up! Thank you very much..
Oct 16, 2008 | Nokia 6101 Cellular Phone
Sanyo Kyocera Zio M6000 - Black Smartphone Sprint Logo
74 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
