Question about Hotpoint Ultima WF860 Front Load Washer
Error code f-13 - Hotpoint Ultima WF860 Front Load Washer
    Sergeant:
  • 255 Answers
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima and other models.
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. error code f-13 - error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-14.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-20.jpg
Posted on Dec 23, 2014
21.2:13 error code HPT770
21:2.13 error- service station fail- these can be ordered but need fitting by an approved engineer
part number CH538-67040
Dec 30, 2013 | HP DESIGNJET T770 Printer
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I am getting a 13 error code . jim B.
Before calling service technician, open following links for troubleshooting resources including Rheem chat and typical manuals:
http://waterheatertimer.org/pdf/Error-code-13.pdf
All gas water heaters require periodic maintenance.
Tankless recommend yearly maintenance.
Typical maintenance would cover most the causes for error 13, plus causes for most other common error codes.
Jul 19, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
Error codes are considered start-point for troubleshooting.
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Error code 0 13
1:Error Code 0 13 could be telling you that your "Air Filter" needs Cleaned.
2: If that does not work Call "Sharp" at 1-800-237-4277, follow the Prompts for "Air Conditioners".
3: When you reach a person give them Reference # 5263448. that is for your current problem, I have already spoke to them about.
Hope I Helped
George
Apr 28, 2009 | Sharp Heating & Cooling
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Vrcd400-sdu error code 13
CD will not go in dis slot
Jan 02, 2008 | Car Audio & Video
Hotpoint Ultima WF860 Front Load Washer Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
