Upgrading windows xp to windows 7 or do i have to upgrade to vista first
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
You cannot upgrade xp to win 7 because the kernels are so different. You can upgrade from vista to win 7. Just do a clean install of windows 7.
Posted on Dec 07, 2014
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
Up grade for windows xp
You need to purchase an Windows upgrade disc to Vista.
If you want to install Windows 7 before you purchase an upgrade disc you should check it your laptop will work with Windows 7.
You can run a Windows 7 upgrade advisor to check if your computer is suitable for Windows 7.
Click on this link to download the check upgrade program :- http://www.microsoft.com/downloads/en/details.aspx?familyid=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
Mar 23, 2013 | Computers & Internet
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
How to Upgrade my Windows Xp
To upgrade Windows XP to a high operating system, you will have to buy an upgrade disk of either Windows Vista or Windows 7.
Mar 23, 2011 | Microsoft Windows XP Professional
Upgrade my acer aspire 4720z to windows 7
Hey
First go to this link and down microsofts upgrade adviser
If this says you can upgrade to windows 7 then either follow
Hope this helps
-Ryan
All sources were created by Microsoft and gathered using the google search engine.
Mar 05, 2011 | Computers & Internet
Can i update window 7 ? now i hv window XP is there any effect of my files available in system during downloading wndow7
Windows 7 does not allow an upgrade from Windows XP. You would have to upgrade to Vista first and then on to 7. Also, it depends on which Vista you have that will determine which Windows 7 you can upgrade to. If you have Vista Home basic for instance, you cannot upgrade to Windows 7 Premium or professional. It is really screwed up. You can however do a clean install but you will lose all your old files unless you back them up on an external drive before running the new OS.
May 16, 2010 | Acer Aspire One PC Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
