Question about Seiki Lc-32b56 32 LCD HDTV
Volume don't work to tv
I have checked AUDio on tv still no volume to tv
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
In the menu for audio, there will be a selection for TV speakers on or off. They are probably switched off.
Posted on Dec 08, 2014
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    Volume on tv not work
    If there is no sound to TV, check its speker first. If is is found OK, check and replace the audio output card.
    May 08, 2013 | Olevia LT42HVi 42 in. LCD Television
    VOLUME STUCK
    you use auxilry port in your tv as volume problem volume out from direct TV cable bos insert in tv auxilry port
    May 17, 2012 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
    Zenith volume issues
    If you don't any Volume at all, unplug the TV from the wall for 40Min, and that will reset the audio processor back to normal, if that don't work, then chek for a audio amp IC that could be bad
    Aug 11, 2011 | Televison & Video
    I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
    Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
    Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
    Feb 28, 2011 | Audio Players & Recorders
    There is no volume on the tv, the volume bar goes all the way to 99 but there is no sound, i plugged in external speakers it worked but the tv volume is not working. How do i fix this problem?
    Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
    If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
    The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
    Good luck.
    May 21, 2010 | LG 26LG30 26 in. LCD TV
    Technics sa-dx940 tv volume control
    Check the sound setting on your TV, is it Fixed level out, if so you have to turn volume up on TV to go through the receiver.
    Mar 19, 2009 | Technics SA-DX940
    Volume does not work.
    Good day.
    You are possibly right. Audio circuit might got affected. I would like to suggest likewise that you check also if the speaker is busted, the audio IC and if it receives supply from the flyback.
    chris
    Jan 29, 2008 | Sharp 27K-S100 TV
    Audio noise on cold start
    hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
    Mar 19, 2006 | JVC AV-32750 32" TV
    Seiki Lc-32b56 32 LCD HDTV Logo
    139 people viewed this question
    Top Seiki Televison & Video Experts
    Andrew Taylor
    Andrew Taylor
    shaun taylor
    Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
