Question about Curtis Lcd4686a 46" 1080p 120hz Full Hd Lcd Tv Ats Hdtv Television 337718
I have a Curtis LCD TV. The red standby light turns on when I plug it in, but will not turn on (either by remote or the physical button on the TV). What could be the problem?
  • Tiffany Mixon
    Tiffany Mixon Dec 07, 2015
    I'm having the same problem have you had any luck figuring this out?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
There could be a list of different problems. Usually, the red lamp will blink in a particular sequence, which tells the tech which board is most likely the problem. This is not a 100% accurate, because another board that has an issue, could cause the first board to interpreted incorrectly by the microprocessor IC(computer within your TV)
Posted on Dec 08, 2014
Testimonial: "There is actually no particular sequence, just a solid red light."
  • Audio Service Clinic Dec 08, 2014
    That would mean that the unit is not switching out of standby. I would start by checking the power supply, but once again, it could be another problem, causing the power supply to look. If you're not a technician, this can be hazardous to your health. Number one thing, there are no schematics for any of the LCD, or PLaza TVs. As I worked for the manufactures, they don't want anyone in these products. Nuymber 2, LCDs have only 3 boards. They are not meant to be troubleshot any more(actually,not for some time). They are repaired to the board level only(unless you're a very savoy tech). The cost of replacing even one board plus labor, is probably more costly than it was to purchase the set.I troubleshoot to the component level, but I work on audio, which makes it imparative to troubleshoot this way. As I told the service centers and techs under my direction, "if you don't learn to troubleshoot to the component level, you will out be of business soon", which is what's happening these days. Truly, the bottom line is, recycle the TV, and go treat yourselfto a new TV. Buy the extended warranty. It will pay off; trust me!
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Remote control not working - not batteries, have changed them. Red lcd light is not showing will not turn on using remote control when tv is on standby
you can use buttons on side of tv to turn on
are batteries in right way
to test remote if you have camera on phone switch it on and point remote into camera and you should see flash of light when press any button if not you can get new remote form charles hyde and son ( CHS ) web site you will need model number on remote
Jan 02, 2010 | Samsung LN-S4051D 40 in. LCD Television
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Sometimes the sound echos like there is too much bass
I have a celestial Tv.LT3200HD. I cant turn it on. red standby light is working. I have tried remote, on off button on side of tv and turning it off then on. Whats next. There is a gamet of colors in stanby red light when trying to turn it on.
Mar 27, 2009 | LG 26LC2R 26 in. HD-Ready LCD Television
LG LCD 37'' standby problem
if you want i will buy the tv from you
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Dec 19, 2007 | Televison & Video
Curtis Lcd4686a 46" 1080p 120hz Full Hd Lcd Tv Ats Hdtv Television 337718 Logo
148 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
