Question about Fun World Toys
What dose fun mean
A bad word which is relly mean so what do i think something really bad
  • 4 Answers
Fun is something that makes anyone happy. It is some tricks that can make people laugh. There are many ways to have fun. Some people do fun very frequently, while sometimes it happens suddenly. Funny moments are always good. Everybody likes to have fun. They enjoy it. So, this is what fun means.
Posted on Jun 16, 2017
  • 5,480 Answers
Fun is not really bad! This is a happy thing!
Posted on Dec 08, 2014
Fan is now shutting off when i stop the engine.
side post battery terminals can be tricky.
The metal platesinside the vinyl insulaters can corrode and fail to conduct for charging or cranking. In extreeme cases pliers my be used to fold the vinyl covers back to clean the metal terminal with a wirebrush or wire wheel in a drill. Care must be taken not to breath the dust or get it in the eyes. Often a pocket knife can be used to scape them and verify tgat tgey are the problem. In some cases new cables can be justified by the amount of corosion in other converting to top post and replacing. The terminals and a bad battery can be an option if the opposite end is inaccessable, the battery is bad and theterminals are in relly bad shape but the wire is still bright copper.
Alternators have passed bench test, produce 13-14 volts but due to worn brushes cannot maintain full amperage at highway speeds for lack of spring tension and output cuts off.
Three other voltage related are oxidized fuse, relay or electrical connector cotacts. Often pulling and replugging them will reestablish conductance a locate the problem but a deox, cleaner and dielectric greese should be used to fix. Also sloppy loose plastic connector or broken connectord can cause intermitant connections.
Melted or worn wires shorting out.
Loose or rusted ground terminations
Bad ignution swutch mine simply fell apart due to poor design, engine would cut out and i had to punch the sterring column to get powered up fun on the freeway.
Nov 29, 2016 | Cars & Trucks
Code search on 02 grand marquis came 024,025,052 for my heater dose not work. What dose the codes mean?
Codes 24/25 are blend door motor codes indicating one or more blend doors are inoperative. Code 52 indicates there is a short circuit in the A/C solar radiation circuit
Feb 20, 2016 | Cars & Trucks
What dose a +- warning light mean on the dash pannel
Not really sure. But those signs would lead me to think the battery and /or the alternator. + is positive and - is ground/earth.
Jan 17, 2015 | Cars & Trucks
What dose funnys mean
Yes you are right! Funnys means something that is Fun!
Dec 07, 2014 | Funny Ringtone Apps Android Apps
What dose parentheses mean in math
Parentheses go in pairs: an opening left parenthesis (, and a closing right parenthesis ). They are sometimes called brackets. A pair of matching parentheses enclose an expression and tell you or the calculator that the content must be considered as a whole. For example if you write 2*(4+5) it means that the factor 2 outside multiplies the whole content of the parentheses. To open (remove) parentheses you must use the distributive property.
Jan 09, 2014 | The Learning Company Achieve! Math &...
Any good tips for teaching my grandchildren to knit? I have always loved knitting and want to share it with them but want it to be fun for them.
Here are some tips to make it more fun:
1. Make it more about creating and having fun than getting good stitches.
2. Try not to teach too many kids at one time so that you've got time to help everyone
3. Start with really simple tasks so that they feel successful
4. Remind kids many times how to start a knitting line. It's something you learn at the beginning and then often forget.
5. Be really proud of their work no matter how badly it turns out. If you encourage them, they will be happy to continue.
Feb 25, 2013 | Crafts & Hobbies
My car wont go into gear, and i found a thick rubber part on the ground . its Round and it appears to have broken off clean
you relly need to repost you question and give more detail, such as, do you mean that the shifter wont move or do you mean that you can put shifter in the desired gear and nothing happens, i would relly like to help but a little more info would help me do that
Jan 10, 2011 | 1998 Saturn SL
Where is it located
Just check underneath it and if that does not work try to check above it.
Other places that you might want to check, places, In something, or on something.
Usually it will be in or on something, as it is pretty impossible to not be in or on something at any time, unless it levitates... then you are really in trouble.
It is a hard thing to determine, but I feel that I have really Nipped this one in the bud. Not many can say that they know the things that I think of thinking about maybe, but I can honestly say that I am not trying to say anything, just sayin', i'm not sayin. Cheers. Have fun with it, now that I told you where it is. :)
-Jackson
http://urbanscooters.com/
Oct 26, 2010 | Ford F-250 Cars & Trucks
Reverse on 98 Jetta with Manual Transmission sounds bad
VW TRANS FOR YOUR MODEL ARE KNOWN TO HAVE WEAK REVERSE GEARS IF ITS CLICKING YOU PROB HAVE A BROKE OR CHIPED GEAR TOOTH IF ITS SOUND REAL WINEY ITS OK,JUST TAKE YOUR TIME IN REVERSE AND YOU RELLY DONT USE IT MUCH ANYWAY.IF ALL GEARS WORK FINE AND ONLY REAVERS IF GIVEING PROBLEMS I DONT RECOMEND HAVE IT FIXED
Sep 30, 2009 | 1997 Volkswagen Jetta
Central heat and air system won't shut off
sounds like tstat is wired wrong or possibly the contactor relay has fused shut outside. if you can stop the system from running at the tsat it is usually a problem with the t-stat
if you cannot shut off the outside unit without turning off the power at a breaker than usually the contact relay needs replacement
Nov 22, 2008 | Ruud UBHC Air Conditioner
Toys Logo
307 people viewed this question
Top Fun World Toys Experts
 Mikey
Mikey
Are you a Fun World Toy Expert? Answer questions, earn points and help others
