Question about Video Game Consoles & Games
How do I get energy,money,and k-stars?
Going on YouTube and looking
What year did "energy star" begin and what if no sticker?. I'm looking for used one, can't afford new. I look up brands and models, but they don't refer to this. Please help...thank you
EnergyStar started in 1992. Here's a link to the EPA energy star website and product list. https://www.energystar.gov/products?s=footer
Sep 22, 2016 | Refrigerators
Tip
Refrigerator Efficiency
The efficiency of your refrigerator can be much better if you take the time to check out a few things before you buy or do a bit of maintenance on your refrigerator. The maintenance part I have covered in another tip, so I will just stick to the things that you can check when buying a new refrigerator in this tip.
Energy Star refrigerators will save you money. Look for a refrigerator rated with the energy star, when choosing a new model. Efficient refrigerators rated with the energy star are listed on the energy star website.
The style of the refrigerator will also make a difference in the refrigerator electric usage. A side-by-side refrigerator will use more energy then a top freezer model. The refrigerator electric usage is higher for those models with the two side-by side doors. If you look at the energy star list you can also see the energy kWh/year usage and see which models use the most electricity.
Some other things you can do so that your refrigerator work is less, includes checking the door seals, cleaning the condenser coils, checking the thermostat settings, and checking to see if you can turn off the door heaters if your refrigerator has them. Cracked or loose door seals will allow air to circulate outside the fridge, this uses more energy to keep the refrigerator cooling. Dirty condenser coils will cause the refrigerator compressor to work harder to cool the fridge. The door heaters also will make the refrigerator work harder to keep it cool inside. Adjusting the thermostats to 0- 5 degree F for the freezer and 36 -38 degrees F for the fridge side will keep your food fresh and still save energy.
Efficient refrigerators are great but they still need to be taken good care of by cleaning and servicing them regularly. Refrigerator electric is one of the biggest electric usages in most homes. Take some time to check over your refrigerator to help save some money on your electric bill.
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
on Mar 13, 2010 | Refrigerators
Where is the neutral switch located on my 1988 yamaha 250 vstar
Replacing the Neutral Safety Switch on a Motorcycle ...
? 4:52
https://www.youtube.com/watch?v=kvS-AbeH-IM
Sep 20, 2010 - Uploaded by ToastToGo
Replacing the Neutral Safety Switch on a Motorcycle (Kawasaki .... When my neutral safety switch was going, the bike would just die all the way ...
Neutral Switch Replacement 2000 V Star 650.wmv - YouTube
? 8:44
https://www.youtube.com/watch?v=IPUkYj9cRWw
Apr 27, 2012 - Uploaded by Casper Riley
Neutral Switch Replacement 2000 V Star 650.wmv ... 2008Yamaha V-Star 650 after market Gas cap, Oil Temp Gauge, ...YZ250F example.
[PDF]XV250T(C) Owner's Manual - Star Motorcycles
Dec 03, 2015 | Yamaha Motorcycles
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Older Model GE Energy Star Front Loader 8 cycle Heavy Duty Deluxe Quiet. Drum makes loud thumping on spin cycle what could it be?
The drum is supported by springs. Maybe one of them broke. You might have to open it up to visually inspect it. You can find videos on YouTube on how to do it. Good luck!
Dec 09, 2012 | GE Washing Machines
Is the Whirlpool Electric Water Heater Model # EE3J50RD045V energy star rated
You want to know if this heater has Energy Star label.
I don't know.
Call Whirlpool 1-877-817-6750
Energy Star is a label that means nothing to you.
Manufacturers use energy-star label to promote a product as a money-saver.
They can put an Energy Star label on a giant 10,000 square foot house, and you know that cannot be the truth that a large house saves energy vrs a smaller house.
Energy factor, (energy factor/ not energy star) on the other hand, is a comparison measure how efficient the water heater uses energy to heat a gallon of water, when water heater is absolutely new.
EE3J50RD045V has energy factor of .59, which is completely typical and ordinary for electric water heaters.
The EE3j 50 gallon is an ordinary electric water heater, with ordinary average .59 energy factor rating, so electricity to operate this water heater is same as any other typical 50 gallon electric water heater: it will cost $35-45 a month depending on incoming water temperature, hot water use, thermostatic setting, electricity pricing, and whether you operate heater at peak pricing, etc.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/How-much-does-it-cost-to-run-water-heater.html
The most important measure of water heater cost does not have anything to do with Energy-star or energy-factor.
The most important measure is total cost of owning and operating the water heater.
So if you spend $100 more to purchase electric water heater with slightly higher energy factor, then it will not pay you back. The difference will be $2 to $4 per year.
All costs are energy.
The total cost of operating water heater includes purchase price, installation cost, cost of repairs, cost of parts, whether you can fix it yourself, expected life of water heater, and replacement cost.
Every water heater has expected lifespan, and will not have resale value except current price of scrap.
Electric water heaters cost more to operate per month than same-size gas water heater.
Gas water heater might cost less over the life of water heater, but gas water heaters are increasingly expensive to repair, and increasingly more complicated, and cost more up-front to buy.
Electric water heaters cost less to buy, are easy to install yourself, are fully repairable by homeowner using generic off-the-shelf parts, and can be made to last many years by keeping tank clean and replacing anode rod every 2 years.
You can make ordinary 6-year electric water heater from box store last almost indefinitely.
Avoid electric water water heater that has electronic controls.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Sep 20, 2011 | Water Heaters
Tv is 10 years old, the red drifts to the right and some times reverts back to normal its a Mitsubishi 1080 55" Rear Projection WS-55809, I found this...
The Tvrepairkits.com to buy a convergence kit,will fix ur red color line or color shadow pictures drifts problems.But u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can u do basic soldering skills work,than u can fix this problems.Yes,the new tv design have Energy Star incorporated in it design and will save u energy and some money,but the power consuption of a big screen tv any century era,still will cost u alot of money to operate it.
Dec 04, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I did not understand what to draw on the topic "More stars more saving". Can u please tell me what to draw??????????
If you are referring to the energy saving rating, then the more stars means the appliance with the greater number of stars is more energy efficient than an appliance with less number of stars and therefore cheaper to run and will save you more money.
Sep 21, 2010 | Computers & Internet
Is my fridge energy star rated?
ALL ENERGY STAR APPLIANCES HAVE A "ENERGY-STAR LABEL" USUALLY LOCATED ON OR NEAR THE MODEL AND SER. NUMBER TAG OR LABEL. CHECK ON THE BACK OR INSIDE THE REFRIGERATOR WHERE THE COLD CONTROLS ARE LOCATED.
Apr 26, 2007 | Kenmore 53612 / 53614 Side by Side...
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
