Question about Cell Phones
What is master pin code for gallery dvd 40753
Forgot My Pin Number
Do you mean security pin?If you forgot your security pin,Try default codes like 12345,00000 or else try to reset your mobile phone using master reset code.If you need master reset code visit Unlocking4free.com They will provide master reset code for Nokia and Alcatel mobile models only.
Jul 23, 2013 | Cell Phones
Plz tell my master reset coe of NOKIA1110i, my IMEI:355515015608969 please help me!
For this issue please you have to contact Nokia gallery for Hard Reset.
Mar 31, 2011 | Nokia 1110 Cellular Phone
I cannot determine if the Internal GH22 Super Mulit DVD Rewriter is in the slave, or master, position. When I installed the DVD, my D and E drives disappeared from the Computer and only the C Drive...
When you examine the rear of the GH22 drive, there's a small square block just to the left of where the ribbon cable connects to the drive.
You should see that there are three pairs of pins running from left to right. You should align the jumper block so that it connects or covers the two pins in the center to configure the DVD as a slave device.
When shipped from the factory, the jumper block is supposed to be covering up the rightmost pins ( indicating a master position). Chances are that the other device on this cable was also a Master device ( where your D and E drives were).
Good luck.
Mondotofu
Sep 18, 2010 | LG (GDR8164B) Internal DVD Drive
What is this code 80040216
This error message can be caused because you do not have an audio output device such as headphones or loud speakers connected.
Jan 30, 2010 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
PIN CODE SET FOR DVD AGE LIMIT ANY MASTER CODE
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Oct 15, 2009 | Philips CDV19BPH 19 in. TV/DVD Combo
Master Pin Code
hi
Jan 22, 2009 | Nokia 6234 Cellular Phone
Pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Oct 08, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
The code din't work
The master reset code is *#7780#
Apr 30, 2008 | Nokia 3110 Cellular Phone
DVD
first try to change your master-slave pin in your CD-DVD ROM
and reconnect bus connections or change your DVD ROM bus.
if the DVD-ROM and Hard disc are connected in a same bus just put them in seperate buses.
Jan 08, 2008 | Computers & Internet
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
