Question about Weedeater 25cc 2-Cycle Gas Blower - FB25
Can a gas powered blower be repaired if it was drooped in pool.
1. let water drain off 2. Drained fuel and replaced. 3. hand cranked about 1,000 times...
  • 706 Answers
It's hard to get it running again...probably it's not worth a try...
- you should open the carburetor, dry and clean it.
then the spark plug has to be removed and dried with a blow torch, also inside the cylinder opening.
then you better buy a can of starter spray to ease a start procedure.
Weed Eater FB25 Handheld Blower Parts Can a gas powered blower be repaired if it was dro - 25311960-50ikml0pgld1svv5r0lj5py2-4-0.jpg 25311960-50ikml0pgld1svv5r0lj5py2-4-2.jpg
Posted on Dec 07, 2014
Truck just died at stop sign a block from home and will not start
assuming the vehicle is a diesel because you say you drained the water separator ? What engine ? What fuel pressure does it have to the injectors ? Do the injectors fire ?
Ford 7 3 powerstroke crank no start due to low icp injection pressure...
Do you know how to trouble shoot diesel engines ? Your best bet take it to a qualified repair shop .
May 06, 2017 | 2008 Ford F-350 Super Duty
AFS is on. Replaced blower still on. e-8 any ideas
is this heater is propane or natural gas ? most of the time is no a blower related even the manual say it is 1-the air vac switch closed the blower run ? 9 out 10 is gas related (air flow switch is call)
Jun 11, 2013 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
RUUD PVP75E-1 Gas Water Heater short cycling
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
Feb 01, 2013 | Water Heaters
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
06 road glide will start, run for approx 5 sec. then shut down. It will not continue to run. I have replaced the crank shaft position sensor, drained and replaced the premium gas, replaced my spark plugs....
Hi Jamesgreenjr, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.Harley Diagnostic Codes 04 to Present
Sep 02, 2011 | Harley Davidson FLTR Road Glide...
Heater is leaking
Close all pool drain valves, also all return valves. This will stop any water being sucked out of pool.
Jul 24, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Natural gas generator will not start. 4 years after installation.
very likely a fuel problem. First pull the air cleaner cover off and try choking the engine by putting your hand over the intake partially choking it. If this don't work then go Down on the bottom right hand side behind the battery you will see a fuel regulator on top of it is a fuel solenoid with 2 wires coming off it. Below the fuel solenoid you will see 2 -1/4" pipe plugs one on top of the other. If you pull the top one out and gas comes out then you have fuel up to the solenoid. If you pull the bottom one out and crank the engine then you should get gas out of the bottom one. If you don't then make sure you are getting 12 vdc to those 2 wires during cranking. If you do then You are going to have to pull the 4 screws out of the solenoid and pull the solenoid off and make sure you the seat on your solenoid valve is not sticking. If all this checks out and you are getting fuel out both 1/4" pipe plug holes, then you will need to see if you have a spark at the spark plugs, if you don't then something is shorting out your ignition coils. Disconnect wire 18 from its terminal located above the oil cooler. If the engine starts and runs with this wire disconnected then you need to trace this wire back to the control panel and see whats causing it to ground out.
Let me know if this helps.
Oct 18, 2009 | Electrical Supplies
Can't start brisggs & Stratton 21in mower. I
Get some GUMOUT carburator cleaner GAS ADDITIVE. Put about 1/2 TEASPOON in the gas tank and about 1 tablespoon per gallon into your spare gas. The float pin is probably sticking from winter non-use. This will free it ip.
You can also remove the bowl from the carburator and spray everything to immediately dissolve the varnish. Be careful not to lose the pin spring.
Jun 13, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Weedeater 25cc 2-Cycle Gas Blower - FB25 Logo
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
