type the numbers or .com address into your browser and find the settings inside your router (box). The password will be in your router or modem settings.
What most likely happened is when you factory reset the device, the wireless setup that you use to connect to the Internet was reset as well. You need to go into the wireless setup area and look for networks to connect to. The one that you use regularly (assuming you are where you use the device), should be among those listed. You then tell the device to connect to the network. This is where the device will ask you for the network password if it is a secure network (and most are). Once you input the password, then the network router will assign an IP address to the device and connect it to the network. After that you can access the Internet normally. If you don't know or forgot the network password, someone in the household (or business) should be able to provide it so long as you are authorized to connect.
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
I recommend that you load the factory default values. With this option you will eliminate any type of configuration that you have loaded. You will tell me the result, greetings.
Hi there! That happens to my child pad as well. I will tell you what I did. Well, I don't remember exactly but I know what the problem is. If it is usually when you just turned it on, its because your settings are set in a way that whenever you log on to it, you have to set the internet connection again. maybe this might help. I really don't know. But that is what I did, and now that doesn't happen to mine...and because I forgot the password. Do you have any solution on how what I can do so I can play on it again? Please share with me if you do. Thanks!! You can just email me at [email protected] Thanks!! :)
It maybe connected by bluetooth, so i think it needs no password, Suggest you to contact Samsung ,they should be helpful. GOOD LUCK. Android 4.0 Tablet PC
i was having the same problem not getting interent on my tablet but could everywhere else and this morning trying once again i actually clicked on my router name on tablet and it went into a submenue where u have more info like password, etc and for some reason my router password was not there, once i entered it i got my internet back again, yeppeeeeee
