Question about Dryers
My wight knight wk767 condensing tumble dryer keeps tripping the electrics in my house when i turn it on the reset button at the is ok what is the cause .
Tripping house electrics when turned on .
    Master:
  • 474 Answers
Simply there is to much load on the breaker so its tripping to protect your home. I'm not an electrician so I am giving you info based off my experience. Some houses, most I think, have a special plug for the dryer and you can buy a different plug that screws on to the dryer depending on which plug your home has. You may need to upgrade your existing plug in the wall if its an older house. Also, I believe that circuits is on its own breaker separate from the rest so it shouldn't Tripp anything else but the dryer\washer. You can easily fix this yourself if you are confident in dealing with shutting off the electricity and rewiring the outlet or the dryer plus. If not then a electrician can do it easily allbet at a fee. Often times the Home depot or Lowes reps will give you advice but you have to understand its only advice. I would take a picture of the plug and the wall outlet and the breaker. This way you have something to show them at the store when you ask about the plug. One other thing it might be is that the dryer has a bad hearing element or sensor and its drawing to much current causing the trip of the breaker but usually dryers have a $50 fuse on the back that's supposed to blow out first.
Posted on Dec 08, 2014
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
My white knight condenser tumble dryer keeps tripping everything. Then if I leave it a white it works again what could it be?
sounds like the water is getting into element you will have to check all filters and check that your pump is working properly
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
My tumble dryer keeps losing heat it still works and i have to keep pressing the button on the back of the machine for it to heat back up
take the vent tube off run dryer, it should not trip your button. You will need to clean the vent tube. Good Luck Tim
Feb 05, 2011 | SNK Knight 43AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Wk767 tumble dryer
it is the motor run capacitor it happened to me i bought a replacement in maplins for about £3 or £4.
Mar 09, 2010 | SNK Knight 43AW Electric Dryer
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
