Question about Garden
What is wrong with my lawn tractor it won't start?
I Hqve replaced spark plug
  • 706 Answers
Is the battery good?
try to use starter spray into the airfilter before a start What is wrong with my lawn tractor it won't start? - 25311948-50ikml0pgld1svv5r0lj5py2-5-0.jpg
Posted on Dec 07, 2014
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
I just put a new carb on my 17.5 hp lawn tractor .... it starts and runs great then after about 2 minutes it cut out .... and won't start for a few minutes .... spark is good ...... any ideas? it is...
It is possible that the fuel line is too close to the engine and the fuel flashes to vapor in the fuel line causing vapor lock. I recommend adjusting the fuel line if posible, and retry. Maybe replace that section of fuel line.
The other possibility is the ignition coil is going bad. You can check it by running the engine and when it stops, quickly remove the spark plug, caution hot. Put plug back into the wire and ground the spark plug and try to turn over the engine with the key start, if good spark, then the problem is likely the other,
I mentioned the fuel line first, because you said that you had been working with the carburetor, and the fuel line may be moved or a little shorter.
I hope this helps you get going soon.
Aug 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor won't stay running, back fires when I turn it off.
It seems as if the tractor was out of its correct timing, also try replacing the spark plugs.
Thanks
Jun 03, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
