Question about Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White
Where can i find a cheap rebuild kit for the pump on a WA37126EW2 washer
  • 4 Answers
If you search Ebay for "Fisher Paykel 420325P Water Pump" I did find one pump for $59. Good luck.
Posted on Dec 12, 2014
Ball valve spring pressure washer detergent line
Not sure what type pump you have but you can buy a chem. injector rebuild kit at Pressure washer parts catalog quick links Pressure Washers High Pressure...
If you need to replace the spring then replace the entire kit. Ball, spring and oring. Most pumps that come on the newer TRoy bilts are AR RMW pumps. the parts diagram can be found here at http://www.arnorthamerica.com/manuals/rmw-om%201006.pdf
The parts for a AR chem. injector are
480480 O-Ring
1250280 Ball
1560520 Spring
Good luck
Jul 22, 2014 | Troy-Bilt 020528 Gas Pressure Washer
Srmw 2.2g26. Can the pump be rebuilt with a kit?
There are two options for this pump regarding rebuilding it. You can purchase all of the repair kits individually, or just buy the complete replacement pump head with all components already installed. This is the easiest/most reliable way to address the repair of the SRMW pump. It is also extremely easy to install, and can be done in less than a minute since you do not even need to remove the pump from the pressure washer (this is the complete pump head that can be found online:
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Oct 03, 2013 | Briggs & Stratton Garden
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Had the seat recovered on my sled(tank/seat combo) and now cant get fuel from tank.sled fires up when fuel poured into cylinders but then dies when fuel is burnt off.sled is a 97 indy sport 440
take the fuel line from tank to fuel pump off the fuel pump blow air threw it and check for blockages no blockages? now the line from pump to carbs no blockages? rebuild the fuel pump cheap easy 20-30 dollars on ebay for the rebuild kit.
Feb 04, 2011 | Polaris ATV
No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Jun 04, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Only runs on prime.....9.9hp
Sounds like the diapraghm fuel pump needs rebuilding. Fairly cheap and simple procedure. Get a fuel pump kit from your local outboard dealer and follow exactly how the old one came apart.
You may also need to get a carby rebuild kit and do that too if it has been a while. Again pretty straight forward. Take photos of carby as you re pulling it apart.
Both these plus a new set of spark plugs and you should be good to go on the water.
Jul 12, 2009 | Bass Pro Boating
Troy Bilt pressure washer model 020209 has very low spraying pressure. How do I repair the pump?
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Jun 29, 2009 | Garden
Where can i find pump rebuild kit for simpson pressure washer? i need o rings and seals
There are so many sites like ebay etc..
The best one is :-
http://www.pressurewashersupplies.com/
Check and let me know, if doesn't find the kit.
Thanks for using "Fixya".
Jun 23, 2009 | Garden
Foaming in pump oil window
I dont know which comet pump you have, but it is just easier to get a new pump from one of the pressure washer companies on the internet and they sell them on ebay. You can also probably get a better pump that will fit your engine as well. Also, have you tried just changing the oil and not fill it too full? On my 5000 lb washer, if i fill the oil too high when I change the oil, it will foam some. Hope this helps you, Rick
Apr 27, 2009 | Northstar Pressure Washer 3000 PSI
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White Logo
78 people viewed this question
Top Fisher Paykel Dryers Experts
linnap
Roderick Scott
Roderick Scott
William Goodman
William Goodman
Level 1 Expert
Are you a Fisher Paykel Dryer Expert? Answer questions, earn points and help others
