Question about Honda Air Tools & Compressors
I do I wire a condor sk r3 /10,0a pressure switch
4 Suggested Answers
  • 19 Answers
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
  • 54 Answers
SOURCE: A DIRECT DRIVE COMPRESSOR & THE PRESSURE SWITCH IS FAULTY
STOP! Your pressure switch is doing what it is supposed to, but the tank check valve is leaking. This valve is usually at the tank where the line from the compressor head enters the tank. The small tube line from the pressure switch probably also goes to this valve. You'll need to clean or replace it.
Posted on Nov 17, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I need a pressure switch for MDL# WL 506206 AJ It's a Condor LR 59232-3
Hi mark25338
If you do not want to retire your compressor just as of yet, then I recommend that you go to a place like Grainger (go to the link) and tell them what you have and what you need,They can help you figure out a replacement pressure switch for the compressor...it may take a little "jury rigging" but it will work with a different pressure switch...as all the pressure switch does is shut off and on with pressure.
Please take time to rate me
Bud
http://www.grainger.com/Grainger/wwg/start.shtml
Here is the page with the pressure switches.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=pressure+switch+for+compressor&op=search&Ntt=pressure+switch+for+compressor&N=0&GlobalSearch=true&sst=subset
Posted on Oct 11, 2012
What is the firing order of a Toyota Condor 2.4 of 2rz engine?
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, at v, trucks. forklifts, boats, excavators etc
Jun 15, 2018 | Toyota Cars & Trucks
Headlights are not working on my Toyota condor what can be a problem
Wiring , relays , fuses , sockets and switches can corrode or fail . Do you have a voltmeter ?
Nov 25, 2017 | Toyota Cars & Trucks
Why no condor pipe tobacco in shops for over 12weeks
Buy online
Condor Pipe Tobaccos - UK Tobacco
www.uktobacco.com/acatalog/Condor-Pipe-Tobacco.html
  1. Cached
Condor Pipe Tobacco is available in 3 different strengths of pipe tobacco from the house of Condor.Original ready rubbed, original long cut & condor blended. Missing: 12weeks ‎12weeks
Gallaher Limited - Condor Ready Rubbed (Green) - Tobacco Reviews
www.tobaccoreviews.com > Tobaccos > Gallaher Limited
  1. Cached
  2. Similar
Condor should be compared to other Lakeland-type pipe tobacco blends, ... It hasn't changed in its aroma, although if you smoke this like no tomorrow the ..... Condor is another tobacco that I have been smoking regularly for over twenty years. .... I browsed on British shops several times, never sure if I wanted to repeat my ... Missing: 12weeks ‎12weeks
Condor Pipe Tobacco from My Smoking Shop Tobacconist
www.mysmokingshop.co.uk/index2.php?mod=category&man=124&cat=69
  1. Cached
  2. Similar
£13.49 Records 1 - 8 - Condor Long Cut pipe tobacco is a cool, slow burning tobacco for the discerning pipe smoker who prefers long cut tobacco to ready rubbed. Missing: 12weeks ‎12weeks Why no condor pipe tobacco in shops for over 12weeks Why no condor pipe...
Aug 05, 2017 | Cooking
I have a 1800 toyota condor, does anyone have the wiring diagram
most likely cause is the horn itself ,check for a feed to the horn before you go any further but some vehicles have a permant feed and the earth is the switch contact connection .if two wires then it could be the latter ? you must check it with a multimeter to determine the fault
Oct 15, 2012 | Toyota Cars & Trucks
Hi mark25338
Bud
Oct 10, 2012 | Campbell Hausfeld Extreme Contractor...
93 nissan condor truck, electric windows are not working.
I suggest to checl label in fuse panel, test voltage at/from motor wires and test if the windows switch have voltage there; could be bad wires (broke) or loss harnesses connections, windows motor go to bad or just a fuse problem.
Hope this helps.
Feb 08, 2012 | Nissan Cars & Trucks
Need to set low level on my compressor
That would depend on the type of pressure control switch it had on it, but all of the ones I've ever seen have it near the high pressure adjuster under the pressure switch cover- VERY HIGH VOLTAGES- RISK OF INJURY OR DEATH- UNDER PRESSURE SWITCH COVER WITH UNIT STILL CONNECTED TO POWER-
On the common switch used (A condore mdr 5) the differential is adjusted by DEPRESSING the nob & turning it.
On MDR 4 the adjuster is directly behind the high pressure adjuster. it is a flat bladed screw attached to a spring-screw in to increase cut in pressure.
You can also get pressure switches with a higher cut in pressure.
In Australia from a company called Ross Brown Sales in N.S.W
Hope this helps
Regards Andrew
Jul 17, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
Nov 14, 2009 | Air Tools & Compressors
2)Turn it off.
pressure switch.
Feb 02, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
93 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
