Question about Dishwashers
I want a service call
I can not get the wheels back on
Front wheel doesn't spin freely and squeaks on 2n'd day i got it.
Hi James:
If New, I'd take it back to the dealer.
If used.....
Set bike on jack so front wheel is raised. Make sure it is secure so can't fall.
1) Remove front brake pads........... spin wheel If it still squeaks, remove wheel and service bearings.
If no squeak when brakes removed, service brakes.
Jan 18, 2016 | Motorcycles
The wheel on my Dirt ***** vacuum fell off. I tried putting the wheel back on but now the wheel is loose.
Hi! We recommend you take your vacuum in to a Dirt Devil authorized service center for repair. We have included a link you may follow to locate the nearest service center to your zip code. Hope this helps!
Service Center Locator
Aug 24, 2014 | Dirt Devil Featherlite Bagless Upright...
Four wheel drive service system warning came on
Your solenoid is stuck causing this issue it's not letting it back to 2wd faulty actuator
Mar 02, 2014 | 2008 GMC Sierra 1500
Cant get the 4 wheel and 4 wheel low to shift back and forth stuck in not sure .
the differential probly needs servicing--chec oil level -bearings cud be bad---------unhook batt and see if checlite gos away---hav vehicle testdriven by a nondealer or go to librarysec 629 for maintenance of transfer cases and more
Jan 15, 2014 | 2007 Dodge Durango SLT
Outlander howling noise in front wheels
with the wheel bearings failure , it is very possible that the "U" joint or cv joints for the front drive were damaged
I would be looking in that area especially as you mention on turning right
Mar 15, 2017 | Cars & Trucks
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to uk-customercare@dorel.eu for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
Wheel tread worn off mamu stroller back wheels
ur not the oly one ive tried 4 day but to no joy!!!
May 06, 2010 | Baby Gear
Service 4 wheel drive
This year model has had problems with the "Encoder Motor" Its is a bolt on unit around 300 dollars if you do it yourself. I would just leave it in 2WD for now.
Jan 19, 2009 | 2003 Chevrolet Suburban 1500
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Owen Barnes
