Question about Health & Beauty
My sunquest pro 16S the bottom secion does not come on
I have Sunquest Pro 16s tanning bed that I have just replaced all of the bulbs. One will still not light. Can anyone help?
There are no starters on the 16s. Did the position work before you replaced the bulb? If not and it still doesnt work with the new lamp, it is either a lampholder or ballast. If it worked before and doesnt now, it is either not in correctly or its a bad lamp, you can verify by swithching with another lamp
Jun 03, 2016 | Health & Beauty
I need to move my sunquest pro 24 but its to big to go through door.
Vera, take pictures as you dismantle and label the parts with masking tape and marker, so you will have no problem reassembling. pay special attention to plugs and wires.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Wolff Sunquest Pro 24RS 220 Volts
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
Sep 18, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
