My HE 4 T washer is stopping in midcycle. H F is flashing. w What could this be
I keep restarting it. It keeps doing it
    Problem Solver:
  • 6 Answers
I am not personally familiar with this model but I did find out that the H,F code relates to water issues, (inlet, outlet, drainage). I also found a video which if you are a DYI person will probably help.
https://www.youtube.com/watch?v=uD729VDjKvg
Hope this helps.
Jim
Posted on Dec 08, 2014
I have a Maytag/Neptune MAH8700 washer that keeps stopping midcycle with an error code of E3
It could be the Balance: Use a LEVEL on the top panel to make adjustments to the lower legs on each corner. Some are screw adjusting and other adjust by lifting the front, sides or back.
Jan 06, 2015 | Washing Machines
Why does drier stop midcycle and need 30 minutes before restart?
OH OH sounds like a bad motor with bad motor windings u can try disconnecting the belt and drum and run motor by itself see how it does then
Aug 30, 2014 | Kenmore Dryers
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Maytag error code F My Nepturn washer stopped midcycle and the panel is flashing F What is wrong?
have a look at this manual:
Maytag manual
Its a PDF file but should open automatically and could take a minute or so depending on your internet speed.
Scroll down to page 15, this will show and tell you what the error codes mean.
I hope this helps
Regards
Mike
Mar 22, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer stops in midcycle and F displays, what could be the problem
washers stops in midcycle and F displays whats could be the problem
Mar 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
General electric washer won't start
no what happens is the control shakes and the solder in the board gets lose only fix is a new board sorry
Dec 13, 2008 | General Electric WCVH6400J Front Load...
Stops midcycle, restarts when you lean on it
If the problem lies with the contacts, then the knob is not the direct problem, it would be the selector switch behind the knob. Although I don't understand how leaning on the to makes the machine work. Are you sure it is not the switch that indicates when the lid is closed? Either way, Yes!! you can simply just change the switch over.
Jul 27, 2007 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
