Question about Electrolux Vacuums
I have a renaissance cansiter vacuum. When I plug in the canis ter no hose attached, it does not come on like it shouldn't , however when I attached the hose and wand I turn it on it will start to ru
Nothing just using the internet for help. Can't find the same problem anywhere.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
It is running properly if you are doing what you say you are.
It should NOT run without the hose and should with it plugged in if the electronics in the hose and vac are working properly. This was the major problem with the Renaissance Model and was only manufactured for a few years.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Posted on Mar 15, 2015
  • 15 Answers
SOURCE: RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Posted on Apr 10, 2008
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
  • 8404 Answers
SOURCE: No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Posted on Dec 11, 2009
  • 694 Answers
SOURCE: Central vacuum won't start even
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Posted on Oct 12, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson dc27 (not ball version) extension wand will
    Sorry to hear you're having difficulties with your DC27. If the wand is jammed, it's likely that the hose was twisted when you replaced the wand on the cleaner the last time you used it. It's easy to rectify:
    • Pull the wand up as far as it will go
    • With the rear of the cleaner facing you, follow the hose down to where it attaches at the base of the machine
    • Grip the section of loose hose and pull it away from the cleaner
    • Holding the loose section of hose out of the way, pull the hose release tab
    • With the base of the hose detached from the cleaner, allow the hose to straighten itself out
    • Reattach hose to cleaner
    You should find following these steps untwists the hose, allowing the wand to move up and down without restriction. However, if you need further assistance, please get in touch with us free so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 01, 2011
    Help me troubleshoot Epic 8000!
    Try a different hose to test the motor. Make sure it's a good one from a working vacuum. If it works, the problem is likely in the switch, wiring, but could be the hose itself. Other problems could the the triac or relay in the vacuum.
    Best thing to do is to take it in to an Aerus dealer and let them troubleshoot it if a different hose doesn't work.
    Note: Do NOT use a Renaissance hose.
    Jun 14, 2015 | Electrolux Vacuums
    Remove handle from hose electrolux
    You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
    May 17, 2014 | Electrolux Vacuums
    Electrolux Vacuum Renaissance Power head brush won't turn
    if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
    give the hose itself a good look over sometimes the wires up by the grip break in the casing
    Mar 12, 2014 | Electrolux Vacuums
    Renny starts as soon as the unit is plugged in....leave the hose off and the unit will not start until the hose is connected
    This is a problem that needs to be checked at an Aerus Electrolux store. They have the tech manuals to troubleshoot the specific problems with the Renny (Renaissance). There are three possible problems involving the electronics in either the hose handle or the canister.
    When the problem was first noted, customers brought their vacuums in and the service managers simply replaced the hoses. That resulted in burning out the boards in either the new hose or the vacuum, increasing the cost of warranty repair/part replacement. Electrolux quickly sent out service updates letting the service personnel know to stop the practice immediately. I can't remember how long it took before we finally got the proper troubleshooting data, but yes, there were a lot of problems with many of the machines. Fortunately for the store I worked at, there weren't many.
    Oct 16, 2013 | Electrolux Vacuums
    I have a hoover elite cyclonic cansiter vacuum the vacuum works fine but I can not get power to the power nozzle
    If there is no suction in the hose it is clogged.
    Remove the hose at the bottom and clear and obstructions out.
    If this does not fix the issue please leave a comment and I will assist you further.
    Thanks
    Mar 31, 2011 | Vacuums
    LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
    Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
    Dec 04, 2009 | Electrolux Vacuums
    Motor on the powermate keeps cutting in and out.
    If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
    Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
    Electrolux renaissance power hose
    If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
    Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
    Vacuums Logo
    114 people viewed this question
    Top Electrolux Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
