Question about Dryers
I got a new dryer Kenmore elite he4t, as soon as I plug it in it trips the breaker. I changed the outletfrom a 3prong to a 4 prong and change the 30amp breaker. But still happens. Any input would greatly appreciated
  • Dryers Master
  • 744 Answers
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
I think you may be jumping the gun here by changing the power cord and breaker.
What is going to trip you breaker are to many appliances on the same breaker, or your receptacle does not have a ground.
You may have a bad control power board. I have gone on service calls where the unit is delivered one day and I am there the next to replace the power board.
Posted on Dec 08, 2014
  • 3 more comments
  • John Dec 08, 2014
    It's a single 10/3 220volt line only for my dryer.the 10/3 line is two hots a neutral and ground. I know everything is wired right as I still have my old dryer, so I took the 4 prong cord from the new dryer and installed it in the old one. Pluged it in no trip and dryer works. I'm thinking that there is short in the dryer from moving or the thermal fuse I think its called got knocked loose. I really don't know and hoping I figure it out soon. So wife doesn't kill me. We bought the set used and it worked when I picked up.
  • John Dec 08, 2014
    Hi Peter,
    I meant to ask you yesterday where is the power board located, and could that have gotten messed up in the process of moving it?
  • John Dec 09, 2014
    I found some other threads that say if the heating element is bad or the line attached to it is broke it well trip the braker right way because the contdinuity is broken. Going to check it with a muiltmeter and I'll let you guys know. Thanks
  • Peter Goodwin
    Peter Goodwin Dec 09, 2014
    John; I assume the new dryer is replacing an old dryer. Therefore, you are not overloading the breaker. A three prong power cord requires a 15 amp breaker and a four prong requires a 30 amp breaker Lets check the power going into the dryer. On the attached pictures are a three prong and a 4 prong power cord hookup. The power check is the same for both. With your meter set on Volts: 'L2' & 'N' = 110 V, 'L1' & 'N' = 110 V and 'L2' & 'L1' = 240 V. Assuming that you are getting these readings, your problem is not at your breaker nor power cord. Your unit is shutting down because your main control board is reading excessive power supply. So, either you have a short at the board or a bad board. It is not uncommon to receive a new unit with a bad board. Make sure before you touch the board that you ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board. Access the power board, Push in on the connector and wires at the connectors. Try to restart the dryer. Go into thw following website. Type in HE4t. A list of dryers will appear - select your model number. The site is: www.searspartsdirect.com
  • John Dec 09, 2014
    Peter, I do have a 30 amp breaker and the right power going to the outlet. I can not even check the power board, because as soon The dryer is pluged in it trips the breaker. I found another thread that says if the heating element is bad it well trip the breaker right away because the flow of electricity is stopped. I'm going to pick up a digital mulitmeter tonight and check to see if that's it. If not is there a way to check the power board with out the dryer having power, I would assume it's the same ad the heating element being checked with ohms instead of volts.
    Master:
  • 474 Answers
Check the manual for how much it needs in regards to power. Is the 30amp enough? Mist likely not if its still tripping it. Is it possible that the wall socket isn't wired correctly? I would check that as well. Be sure you xturn the power off to everything and test it before sticking your screw driver into it.
  • 156 Answers
SOURCE: sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Posted on Mar 19, 2008
rockitman187
  • 2559 Answers
SOURCE: Kenmore 400 series electric dryer
  1. Remove safety plate (usually attached only by 1 or 2 screws)
  2. Remove old cord and restraint with a hand or cordless drill.
  3. The restraint is the collar that fits tightly around the cord to hold it firm to the dryer.
  4. Connect the center wire of the 10/3 cord to the center silver terminal. Turn screw in firmly but not too tight.
  5. Now you have two wires remaining which are attached on either of the two terminals beside the silver terminal. It does not matter which wire goes on which terminal, as both wires are hot. Screw in firmly.
  6. From the outside of the dryer, you need to slide the tab end of one of the collar halves into the 10/3 cord wire hole. Do the same with the other half of the collar,easily draw the two halves together to tighten against the cord .
This is the 4 wire view 43fa7d5.jpg This is the 3 wire view
Please rate this a fixya
Posted on Feb 08, 2009
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Dryer model 86683100. I need to change
Yeah, red and black go to the outside terminals, white in the center and green goes to the cabinet. What I do is hook up the red, white and black, then I place the green between the terminal block cover and the frame and screw it in tight.
SG
Posted on Apr 05, 2009
protek480
  • 1723 Answers
SOURCE: Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 11, 2009
  • 2468 Answers
SOURCE: Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Posted on Feb 07, 2010
Converting a 3prong to 4 prong electric outlet, need order of colored wires
call an electrician before you kill yourself or burn down the house
Feb 20, 2018 | Kenmore Elite HE4 Electric Dryer
I have a Frigidaire Affinity front load dryer that will not come on at all. The lights won't even come on. We had to change the cord out to a 4 prong and when we plugged it in it surged. What could...
Hi, Sounds like you hooked the cord up wrong... tripped the breaker...fix the cord and reset the breaker...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 10, 2011 | Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
The dryer cord does not match my plug. is that cord required or can I buy another dryer cord and use that instead?
cord for dryer should be 3 prong and center being L shape or a 4 prong dryer corder with an L shape either one is fine aslong as its a dryer cord ,,,, donot put range cords on dryers they use different amperages and could trip your breaker and cause electrical overheating of wiring....
Jan 28, 2011 | Kenmore Elite HE4 Electric Dryer
Can I go from a 3prong outlet to a 4-prong outlet? If so, how can I wire it. Thanks
heatman101
Jan 27, 2011 | Amana Dryers
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
Is it safe to use a 3 prong dryer cord on my 2004 Kenmore Calypso dryer? I moved to an older home with a 3prong outlet.
It is safe as long as it is wired correctly. The following link explains the differences between 3 and 4 prong configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Just make sure to match the corresponsing wire colors at the terminal block in the back of the dryer:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
In a 3 wire configuration the Neutral (White) and Ground (Green) wires are terminated together at the terminal block.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
The other alternative is to have an electrician install a 4-wire receptacle in your home.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 31, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer surface gets extremely hot when
Classic of a clogged vent to the outside, Air out back of dryer should be same outside. Dryer will get hot and take to long to dry clothes with a clogged vent. Pls leave a FIXYA rating.
Aug 24, 2009 | Kenmore 63942 Dryer
Dryer won't turn on, outlet works, cord works, but nothing works!
Read through the following link and make sure you rewired the dryer correctly:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, please let me know. I hope you find this information helpful.
May 12, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
