Question about Whirlpool duet Washing Machines
Duet sport. Tub moves from front to rear banging the front of the machine. Bearing problem?
Nothing yet. Have a feeling it needs new bearing. Maybe use it for target practice next.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
Sounds like you nailed it.
Posted on Dec 07, 2014
My washer makes a LOUD noise when spinning, has done this since new but is getting ubearable. my washer is about 4 years old.
The problem here is with the rear tub bearing. Unfortunately the bearing is not sold separately. So the rear half of the tub will have to be replaced.
any further questions lease feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet makes an awful banging noise when a load of laundry is in the spin cycle. It is completely level and I cannot figure it out.
reach inside drum that turns and try to move it up and down. If there is any movement the spider at the rear of the drum is broken. Will need inner drum and outer rear tub with bearing and seal.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Made a loud noise and drum stopped moving
the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Change rear tub bearing
the nner tub and outer tub (rear section) need to be replaced,the bearing is mounted in rear section of tub, the entire unit is removed fromthe machine from the rear of machine in order to relpace. new pulley, nut, as well. not and easy job, and can be very costly paying for those parts.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The inner tub is out of balance and rubbing against the outer tub
The rear bearing is part of the back half of the outer tub. In some cases the basket will need replaced also if the shaft is scored. This is a big job. In most cases whirlpool will warranty the parts for 10 years but not the labor. Will need to check in your owners manual. Hope this helps
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tub is very loose bangs and wobbles
suspect basket support broke basket will need replaceing and possible rear tub section if bearing/seal damaged overloading not usually not the cause
Nov 27, 2008 | Kenmore 43052 Front Load Washer
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
