Question about Humminbird 898c SI Combo GPS Receiver
When I turn on my 898c si I get a screen that says "waiting for test command" I am unable to get past this screen to operate the unit
I have turned unit off, disconnected it from power, pressed power & menu button simultaneously to see if unit will hardboot.
Can I view on computer?
No Alice, you can't. The only thing you can do is put an SD memory card and put it in the unit and save screen shots for viewing on the computer. To update the firmware and programming, you load to an DC card on the computer and then insert it in the unit. The unit always remains on the boat.
I had the 798CSi, and now have the 998 HD.
Dec 11, 2015 | Humminbird 898C SI Side Imaging Combo 7...
My humminbird 898c is stuck on the loading screen, won't turn off or anything, any ideas?
First steps (you may have done done) check all wiring connections ,transducer, power,ext. at both ends. Attempt power up again. No change. Call 1-800-633-1468 with model & serial #'s. OR Disconnect all cable connections from unit and with a strip of aluminum foil short out all the connections on the 898c.(not the cable). Attempt power up again. If unit will let you go to 'System Status' screen & record. Hope your unit works.
Apr 05, 2015 | Humminbird Boating
Jandy lx 250 invalid command message
is unit on a controller if so take off remote
Jul 06, 2013 | Jandy Laars Lx 250,000 Btu Heater
Blue screen panic
Try turn off computer, start holding down Command and S and wait until text stops scrolling.
Type in fsck -fy
Press Return and wait for the process to finish.
If it says that the disc has been changed, do it one more time.
When finished, type Reboot [and press return]
The computer should now reboot and the problem may have gone away... If not, you need to test the disk and if that is ok, maybe reinstall. You probably would like to go to a pro for that. Hope this works out...
Jan 30, 2013 | Apple Mac OS X v10.5.6
Why does my 898c always say low voltage on the screen
Hello
Check the input voltage to this device. To work properly without any error, the input voltage at load condition [Switch ON condition] should be more than 11.7VDC. If this voltage drops from this threshold, the unit will display 'Low Voltage"
The fault is nothing but with its input voltage itself. OK.
Dec 17, 2011 | Televison & Video
Correct installation/placement of humminbird 898c si transducer
You can take a picture of the transom of the boat and email it to our customer service group and they will give you an idea of where the transducer needs to be mounted. There email address is service@humminbird.com.
Feb 12, 2011 | Sport & Outdoor - Others
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The phone rings but I am unable to answer. I
if your unable to answer the phone, just hang up and wait for another incoming call or press the power button
Oct 13, 2009 | Google Android
Switched to command mode DVD1(I know...) book: you will be unable to operate this recorder. That's all they wrote. Can't undo. Nothing works-screen freeze. HELP???
To solve the problem you need to change the command code on the remote control to 1. Point the remote to the unit, and press 1 on the remote.
I had the same problem also.
May 15, 2009 | Sony RDR-GX355
Uploading photos
You have to check and see if you're losing packing via command prompt. That could be the problem, although if this is a short time period it could just be the site
let me know pls
Dec 31, 2007 | Computers & Internet
Humminbird 898c SI Combo GPS Receiver Logo
89 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
