Question about Tappan Kitchen Ranges
My Tappan range will not open after I tried to run a self cleaning cycle. The cycle never ran and oven still locked.
Tappan ES200/300 range will not open after trying to run a self cleaning cycle.
  • 1,249 Answers
Try removing power for a few minutes and when power is applied again the unit should reset.
Posted on Dec 07, 2014
Testimonial: "Thanks but I tried that and it didn't work. Keep getting a message F3."
  • 3 more comments
  • jeff5may32 Dec 09, 2014
    Bah, electronic controls! F3 means the control can't read the oven temp sensor. Time to break out the multimeter. Oven temp sensor should read 1100 ohms at room temperature. Easy to check and or change.
    If the thing reads good at its connector, try reseating it by plugging and unplugging a few times to break up corrosion.
    If the oven still complains after you've verified the sensor is ok, the problem lies further up the wiring or in the control. Bad solder and overheating are common problems with modern appliances.
    I have a whirlpool gold dryer that has its button panel levitated over the body on 1/2 inch stilts. It was a way easier fix than replacing an overheating control with a new one that would end up being cooked the same way.
    Plus a control panel was $234, spacers were $2
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Ran the self cleaning cycle - Now it keeps posting un lock dor. Lock bar easily moved to the unlocked position after cycle completed and oven was cooled. I have unplugged the oven waited 10 minutes and...
Your switch isnt right ,check the wiring on the switch or make sure the switch is closing or opening when its suppose to,you should hear a click each time it opens or closes. your problem is in the switch area no where else,the computer on the oven needs tosee that switch input and doesnt
Feb 15, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Self cleaning oven
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 10, 2010 | Tappan TEF242 Electric Kitchen Range
Tappan self-clean oven door locked shut, fan keeps running
Did you give it time to cool down? If so, probably a control issue.
Sep 01, 2017 | Tappan TGF320 Gas Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Tappan electric range door locked
Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
Dec 13, 2007 | Kitchen Ranges
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Kitchen Ranges Logo
141 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
