Question about Kenmore 14 Gallon Humidifier Model 15420
Shows a EE on display of 15420 model Kenmore humidifier ... what is that?
I am missing the support, float #829815 and #830496-2. Just bought the unit today and unpacked it and found that it was missing these two parts.
make sure tat the missing parts are not still in the packing material ( foam blocks)
If you cannot find them at all then take it straight back to the retailer and get a refund as it is not fit for the purpose
Feb 12, 2016 | Kenmore Whole House Humidifier Replacement...
Where do I register my Kenmore product on line
try going to the Kenmore website:
www.kenmore.com/customer-care/
Nov 15, 2014 | Kenmore Whole House Humidifier Replacement...
How do you take apart a Vicks 3700 humidifier and clean the fan?
Hello Judith,
Here is a Youtube video that should help you clean your humidifier.
If not exactly search through Youtube for more specific details. You may find many helpful videos with proper search, but be sure to watch video completely to be sure it is the task you are trying to accomplish.
PEACE
Kaz com How to clean warm mist humidifier
May 25, 2014 | Vicks V3700 Starry Night Cool Mist...
Kenmore humidifier model 15420 wont turn on.
If its like mine, one or both of the fans short out causing the fuse to blow in the controller. I was running with a replaced fuse and 1 fan while waiting for a replacement fan. The remaining fan also blows the fuse now. I think maybe there is a fan issue?
Feb 23, 2014 | Kenmore 14 Gallon Humidifier Model 15420
The Humidifer will not reach desired humidity level
most I see have a dipole motor with an atomiser wheel on it..this takes the water and makes a mist out of it..your issue may be that the motor bearings are dry and need wd 40..the disc should turn freely if its stiff the blower will not turn.. needs oiled up..
Jan 24, 2014 | Essick Air Essick Pedestal L Humidifier -...
I have a Kenmore Progressive 295 air purifier. I have the model number for the large filter and the dimensions of the carbon filter but, because it is older, can't seem to locate comparable replacement...
Have you looked at Sears' online parts store? Type in the model number, and it will display available replacement parts.
http://www.searspartsdirect.com/
You can also get there from the Sears home page:
http://www.sears.com/
Click "parts direct" at the top of the page.
Mar 10, 2011 | Kenmore 335 CADR Air Purifier
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
Time On
There should be a timer button that can be depressed to set the amount of run time desired up to 8 hours.
If you press the timer button 9 times it will return the unit to no timer control function and the display panel should show no time in it's window.
Mar 15, 2008 | Kenmore AC2044-1 Air Purifier
Kenmore 14 Gallon Humidifier Model 15420 Logo
128 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
