Question about Water Heaters
How do I erase error code 1l
Turning unit off; unplugging unit
  • Water Heaters Master
  • 5,245 Answers
1L is scale build-up in heat exchanger: delime tankless unit:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#delime
If error code will not reset afterwards, then holding both arrow buttons down on remote might reset error code.
Models have changed since this pdf was posted in 2008
http://hometips.me/Tls/Clear-fault-history-Service-manual-2008.pdf
If error does not clear, then call Rheem and expect them to try to sell you a service call.
Gene
Water Heater Timers Save Money
Posted on Dec 08, 2014
1L code? How to reset ?
can we have make and model please and a fuller description of the issue. Do you have an owners user guide for the unit?
Jun 08, 2016 | Water Heaters
Getting a f76 code on model # ncc-199 sv
F76 is usually a communication error between the remote and the heater. you may have just unplugged something inside the unit while it had power (don't do that). Just unplug the unit from the wall (or flip the breaker) and wait 10 sec and plug it back in again and the problem should fix itself. Otherwise there my be a loose wire going to your remote. In which case, try unplugging the remote and unit for 10 sec and plug the unit (only) back in with the remote disconnected. run your hot water and see if it works. if so it could be a problem with the remote or its wiring.
Dec 08, 2013 | Noritz Water Heaters
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
The hot water just turn cold by it self and wont come back. I have to go to the attic and unplug and then plug back, it will then work. It does this again next time in the shower, midle of the shower,...
Before calling service technician, open following link for troubleshooting resources, including possible manual, and Rheem chat.
Rheem usually asks you to call local service technician.
There are many factors that cause problem you describe: bad PC board, sensor problem, loose wires, crossover in single-handled faucet, lime build-up in heat exchanger, clogged water filter.
The remote control might give you an error code. Error code is a starting point for troubleshoot.
Error code on one unit can have different cause than same error code on different unit.
Read manual for required maintenance.
Tankless require yearly maintenance.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
The water heater cuts off every night while taking bath. The water turns cold and up to the attic we go to reset. A code of C713 is flashing.It also is flashing the code 1L after resetting. This is a Rheem...
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the error codes
The manual will also have the error codes.
The person who installed the unit will also know the error codes (or should know)
Each day I see 20-25 unanswered questions about tankless water heaters.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.rheem.com/products/tankless_water_heaters/
The link above goes to Rheem tankless water heaters
Click on a product and it opens a page showing many tankless models
Click 'more information' and another page opens with spec sheets and other pdf
Not surprisingly there are no troubleshooting steps or troubleshooting flowcharts
There are plenty of ways to buy a tankless
There are not many ways a do-it-yourselfer can fix a tankless
Oct 30, 2010 | Rheem Tankless Hot Water Heater...
I have a 1L error code. Can you help? I have a Rheem RTG-53 PVP. Tankless water heater. Works great. Except for the Error code.
Hi stevenandarl,
Contact Paloma/Rheem customer (800-432-8373) support; tell them the code you are displaying. Rheem will send you instructions via email if you feel you can perform this operation yourself. Or they will recommend a professional in your area to help you.
Mike...
Nov 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
109 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
