Question about Kenmore Vacuums
Kenmore intuition non-turning beater bars, beltless model
We cleaned out any lint in the bars, and pressed the reset button, but the beater bars still don't turn on. Only two years old, and rarely used.
  • Kenmore Master
  • 2,540 Answers
When you press the reset button does the vac motor start but the bars do not turn? If so the drive belt may be broken that drives the bars. If so you will have to replace the belt. If the motor does not start it is possible the belt could be jammed or the motor seized or burnt out. If it's not very old check to see if it's still under guarantee.
Posted on Dec 16, 2014
Beater bar wont spin on kenmore intuition upright bagged vacuum
Start with a new belt if your model has one.
Dec 27, 2016 | Kenmore Vacuums
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore model 401.39035900 vacuum cleaner beater problems
probably need a new motor and beater bar.
Feb 20, 2013 | Vacuums
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
I have a kenmore beltless upright the beater brush dosetn spin
If it is direct drive then the motor or the wireing to the motor are bad. If it is gear driven then the gears are probally stripped.
Apr 11, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
My kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Mar 24, 2009 | Kenmore Progressive Bagless Upright with...
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
98 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
