Question about Boating
I have a evenrude triuph 60 hp outboard moter i am not geting water tru the motor
    Top Expert:
  • 43,148 Answers
Sounds like you need the water pump repaired.
Posted on Dec 09, 2014
How do I tell what model year my 85 Evenrude starflite motor is if I cant find a compliance plate ???
go google and type in-- evinrude outboard 1985 ( you have to put the hp in ) and there are sites that will help the model of the engine
take what ever information you have on the engine ( year , make , hp sales name etc) to an evinrude service center and have it identified that way
Oct 02, 2016 | Boating
What year is my Evenrude 5.1 outboard
provide a model number and perhaps someone can assist you .
May 10, 2016 | OMC Johnson Evenrude 9 1/4" X 9" Stainless...
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
How to install a evenrude outboard water pump
the exhaust ports start from the side of the engine block 2hp -90hp then v4 and v6 and v8 are between the v blocks ! from there they go down the leg unit , top rear of leg have an outlet for tickover then the main outlet is either through the prop or above it on small or old type engines !
May 09, 2014 | Boating
60 HP Evenrude engine can not find a modelnr and is made in Japan I think it is from about 1980 /85 2 cilinder
Evinrude outboards are American built ! on the side of the piston block there is a core plug with the serial number on it also sometimes a sticker on the cdi ignition brain with year of make ! if the engine is original colours then take pic's and take to a dealer or send to age it etc !
Sep 03, 2013 | Boating
Frozon 50hp evenrude outboard motor how to get it running
You first need to know what is "freezing" it. So drop the lower unit and see if that may have been the problem.
Now pull the spark plugs and see if there is any debris on the end (like melted pistons or lots of rust.
Next pull the flywheel to see if the ignition has come loose and jammed it.
If all those things are clean- you have a crankshaft/rod problem with many causes from water in the engin to a broken reed valve going thru the motor.
Nov 06, 2011 | Light Outboard Motor Boat Bass Fishing...
I have a 1973 Evenrude 50 hp outboard motor, when i turn the key nothing happens
it is either a wire broke or the the starter solionde is broken check with volt meter at starter + and - if it shows up voltage its the brushes in the starter motor
Jul 13, 2011 | Boating
Water does not come out of the port hole all of the time.
you might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Apr 27, 2010 | Boating
Boating Logo
90 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
