Question about Sansui Televison & Video
I have a Sansui HDPDP4200. It will not turn on. I did notice a green flashing led inside the back. Any Suggestions? I am also in the market for a schematic for it but have not been able to locate one
I hear a click of a relay when i first try to turn it on, but only when i first try it. Also i opened the back up and there is a steady flashing green led.
    Sergeant:
  • 295 Answers
More than likely a power supply board issue. Unable to supply the correct voltage. If you can find out how many flashes the power light goes on/off. This is a key information to know what diagnostic it is giving you. Plasma's could be trickey as it could be the power supply or an Inverter board to try and power up the plasma screen.
Posted on Dec 08, 2014
I have a sansui 4200 trying to find the d12 board the light flashes 12 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 20, 2015 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Hi, I own a Sansui HDPDP4200 42 inch Plasma and recently it stopped powering up....When you hit the power button, the green light comes on for about 2 seconds then shuts off - No audio or video persent...
We are having the same problem with ours, the power won't turn on with remote or button on TV. Advice on here was leaking capacitator needs to be replaced. We haven't had it repaired yet but figured I would pass this along to you.
Dec 05, 2010 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
How to switch to dvd mode
If you can provide the RCA remote model # I can be more specific (it should be located on the back or inside battery case.
Anyway depending on whether your remote uses 3 digit codes or 4 digit codes the Sansui TV code is usually 191 or 1191.
  1. Press and hold the TV button on the remote. LED will stay "ON".
  2. Enter the code for your brand of TV into the remote while continuing to hold the TV button down. LED will go out during number entry and turn back on when the last digit is entered.
  3. Release the TV button. LED will flash and go out if number is entered sucessfully, or flash 4 times if it detects an error.
  4. Press Channel up or down to see if this has worked.
You can also use the code search function.
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Mar 21, 2008 | Sansui H TV2600 TV
Sansui Plasma, Green and Red Snow
I have the same tv - change the power supply. Corne Bronkhorst
Mar 14, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Feb 03, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Sansui hdpdp4200
you can try to unplug the set for one day and see if the set returns to originle settings.
Dec 16, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
