Question about Xerox Phaser 7400/DX Laser Printer
Phaser 7400 14: real time clock
The printer boots up but stops when the screen reads 14: real time clock
    Novelist:
  • 140 Answers
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Posted on Jan 02, 2015
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Emachine T 5212, when i turn it on,, a siren sounds,,then computer shuts off
In your computer (as well as other gadgets), the battery powers a chip called the Real Time Clock (RTC)chip. The RTC is essentially a quartz watch that runs all the time, whether or not the computer has power. The battery powers this clock. When the computer boots up, part of the process is to query the RTC to get the correct time and date. A little quartz clock like this might run for five to seven years off of a small battery. Then it is time to replace the battery.
This does not explain why your computer would not boot, however. You would expect the computer to boot fine but have an incorrect time and date. The reason your computer would not boot is because the RTC chip also contains 64 (or more) bytes of random access memory (RAM). The clock uses 10 bytes of this space, leaving 54 bytes for other purposes. The BIOS stores all sorts of information in the CMOS RAM area, like the number of floppy and hard disk drives, the hard disk drive type, etc. If the CMOS RAM loses power, the computer may not know anything about the hard disk configuration of your machine, and therefore it cannot boot.
Many more modern computers are not quite so dependent on the CMOS RAM. They store the settings innon-volatile RAM that works without any power at all. If the battery goes dead, the clock fails but the computer can still boot using the information in the non-volatile RAM area. I would change the battery and make sure unit is unplugged and my other hand is touching the metal frame on the computer to stop static discharge. Blow out the inside of the computer completely.Start computer with case off and make sure all the fans run and don't sound like a siren.Replace anything not running.It may not boot if the BIOS can't see the hard drives. You might have to start computer and watch the screen and when it asks you to hit a key to get into like the bios do it and see if you can reset it. If nothing seems be running right maybe the power supply went out they are real cheep at Tiger Direct.
Jan 24, 2013 | E-Machines eMachines Desktop PC
Can't read the display window on Xerox Phaser 8560
I have seen the same behavior on my 8560N. Sometimes the screen will be backlit, but the characters on the display are garbled. Other times, the backlight is off and the screen is blank. No manner of button pushing or tweaking the printer web server will bring the display back on. After a while, the display will just clear itself. I did not see this behavior until after I had a REALLY bad paper jam and some cardstock became lodged inside the print engine. I had to take the printer body panels off (which required disassembling the display interface. When I put it back together, everything worked, but the display started this strange behavior the next morning. Is it related? I don't know, but it sure was coincidental timing if not related.
May 18, 2010 | Xerox Phaser 8560MFP Laser Printer
The screen on my Phaser 6360DN is to light to read, is there a way to adjust thee contrast?
On control panel press DOWN button to highlight "PRINTER SETUP". press OK. Press DOWN button to highlight "CONTROL PANEL SETUP" press OK. Press DOWN button to highlight "CONTROL PANEL CONTRAST" press OK then press UP or DOWN button to adjust. Repeat for "CONTROL PANEL BRIGHTNESS" if required. Press RETURN several times to go back to HOME screen
Apr 20, 2010 | Xerox Phaser 6360 Laser Printer
Problem with my Phaser 7750
Sounds like the NVM was corrupted and it can't boot properly.
Probably needs to have the firmware reloaded.
Apr 01, 2010 | Xerox Phaser 7750DN Laser Printer
How do I set the time and date for the fax on my Xerox Phaser 3200MFP
From xerox.com support for Phaser 3200
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
  1. Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Refer to the table below to enter the current date and time using the numeric keypad.
    Unit
    Range
    Month
    01 - 12
    Day
    01 - 31
    Year
    four digits required
    Hour
    01 - 12 (12-hour mode)
    00-23 (24-hour mode)
    Minute
    00 - 59
    NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
    Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
    If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
  5. When the date and time are correct, press the [Enter] button.
  6. Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
Jul 29, 2009 | Xerox Phaser 3200MFPB Multifunction...
Phaser 860 - Boss said get a kit with a lighting warmer.
MaverickSolutions.biz gets all of our Phaser parts from DocJams.com. They're real experts in Phaser printers, reasonably-priced, and provide terrific support. Tell 'em we referred you.
Jan 15, 2009 | Tektronix Phaser 860DP Thermal Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7400/DX Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
