Question about Bush Televison & Video
Hi, I have a Bush B320HDPVR and it had frozen and cannot change channels.
Unplug everything
I would like to find out the TV code for my 55' Bush tv so I can programme my sky TV remote please.
Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
Mar 31, 2016 | Bush Televison & Video
My mum has a 26" bush tv, model no a626, serial no
Check and replace its main system control memory IC. It is faulty.
Sep 08, 2013 | Televison & Video
Having problems with bush b320hdpvr
Check and replace its main system control IC. It is a very small IC. It won't cost more. It is defective. Will look like this.
Dec 26, 2012 | Televison & Video
Bush b320hdpvr when on standby tv gos off why????What's your problem?
I had the same problem on myBush B320HDPVR. The solution that worked for me was to press MENU -> SETUP -> CONFIGURATION and then set the LOW POWER option to "NO".
John Latter
Jun 06, 2012 | Televison & Video
My Bush 24" TV is only showing a white screen !
Check the video output voltage to CRT board. It might be absend.
Apr 26, 2012 | Bush Televison & Video
Hi there could you please tell me if i can get analogue channels on a bush A series A6 32inch lcd tv.Could you please reply as soon as possible please many thanks Steven.
If there are any analog channels and its tuner is ATSC only get an older VCR and hook it up AV jacks Change channels with it .There dirt cheap flea markets etc.
Oct 23, 2010 | Televison & Video
Hi have a bush LY221WCW with built in freeview but all i can get is the bbc channels !!
test with a vhs all channels and if you leave you have to change the channel selector
Aug 20, 2009 | Televison & Video
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
