Question about Dryers
We have a wgd5300sqo dryer. It won't start. Was
We have a wgd5300sqo dryer. It won't start. Was working yesterday when we cleaned out the lint traps and everything. Worked for a bit. Now won't start again. Not sure where to go from here
    Master:
  • 706 Answers
Plugged in, door closed at the way? These things don't usually break without a warning rumble. If it appears to be ok, I would call APPLIANCE SERVICE GUY.
Posted on Dec 07, 2014
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
ndguy2481
  • 251 Answers
SOURCE: Cleaning the dryer lint trap compartment.
use ur vaccum hose and vaccum it out
Posted on Nov 26, 2008
  • 91 Answers
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
Posted on May 28, 2009
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Lint filter light flashing...on off light flashing. Cleaned lint filter and checked vent. Vacumed and brushed out lint area. Will not turn on.
Had the same problem. I clean it the way you mention with the addtion of blowing compressed air through the vent pipe and it still failed to work. I unplugged the power for a couple of mintues, still did not work. I rotated the dial and pressed start at each position. In the "SHORT" position, it worked and subsequently worked in all positions there after.
Mar 28, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
