Question about HP Pavilion Computers & Internet
How do I install a battery in my laptop - Pavilion HP Computers & Internet
    Master:
  • 706 Answers
Go to HP.com for assistance. Under support tab find your model, then replace battery page.
Posted on Dec 07, 2014
Toshiba laptop battery drivers
Is the battery the EXACT same power spec? Some inexpensive aftermarket batteries don't work will with your laptop, the pins/ connections aren't always a match. That said, Is there a Battery Learning section in your laptop's BIOS? Drivers can be found here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Dec 28, 2012 | Toshiba Satellite P305D-S8900 Notebook
I have an Averatec Laptop computer and I just got a fresh installation of Windows 7. The problem is that after the installation, the battery does not charge and the OS suggested me to replace the battery....
It is coincidental that your battery is not charging after a fresh installation of Win: 7.. Your operating system has nothing to do with the battery charging.When you plug the power adapter into the laptop, does the charging indicator light up?. If not replace the adapter.
If your laptop battery is more than 3 years old , its reached the end of it's duty cycle . A new one should set things right.
Mar 08, 2011 | Averatec Battery for 2100 Series
Acer Aspire 5050 I bought a new battery . My laptop works fine on Ac power but when I installed the battery it shuts off immediately
I apologize that I am having a hard time following the thread as to what you have tried and so forth. I will assume the following:
1. You have an old battery that does not hold a charge but the laptop does run with this battery installed, from AC or from AC w/no battery installed.
2. You have installed the new battery (with the laptop off) and it does not run from the battery or when plugged in.
3. You have tried charging the new battery 4-6 hours.
4. You are using the original charger or one that is fully rated for the laptop - I think this needs a 90W.
New question: does the charge light come on?
If the above are all true then there are 2 possible problems:
1. Bad (shorted) battery - this is possible, although unlikely, fro a new battery.
2. Power connection on the motherboard is faulty. The center pin may be loose, thus not giving full power to the system to charge the battery and run the laptop at the same time. This should be "overcome" by charging the battery w/system off. OR, the connector is like a headphone jack in that when you plug in, the primary connection is opened but on this series of laptop I have seen this fail.
Try powering up with the battery in and adapter plugged into the laptop but not to the wall.
Let me know what you discover. Reply w/my name so I know which thread to read.
Jon
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
Laptop battery problem
Try not to install the battery while its on. Power down the laptop then install the battery and power back on the laptop. Hope that helps.
I have HP compaq nx6110 laptop with fogoten BIOS password what should i do?
You will need to:
  1. Turn off the laptop.
  2. Remove the battery.
    Remove the two screws that secure the keyboard.
  3. Remove the keyboard.
  4. Remove the battery "RTC".
  5. Leave it in this state for 15 minutes.
    Then connect only the main power cable WITHOUT the battery installed.
  6. Power on the laptop, and the RESET is done.
    Power off the laptop.
  7. Reconnect the “RTC”.
  8. Re install the keyboard.
  9. Re install the battery.
  10. Make sure there are no spare screws.
  11. Power up the laptop and continue to use.
Sep 09, 2009 | HP Compaq nx6110 PC Laptop
Laptop will not boot if battery is installed
Have you tried going through the setup screen and selecting the default values for the BIOS? Usually that is necessary any time the battery power is lost.
Dec 27, 2008 | Sony VAIO VGN-T370P/L Notebook
Battery not charging after os installation EVO N160 C
Lithium Ion batteries aren't something that you can really calibrate unless the laptop has a utility in the bios to do so (ASUS laptops). You either have a motherboard related malfunction in reporting the battery life as you say it does report in another laptop, or you need to update the ACPI driver which you can get from the manufacturer's website.
Nov 10, 2008 | Computers & Internet
Need directions for installing compaq nc6000
I don't understand your question here?. If you are trying to install a laptop battery, then you probably just have to turn the laptop over and insert the battery in the compartment on your laptop in which the battery is supposed to go. I hope this helps you out.
Sep 07, 2008 | HP Compaq nc6000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
